It is a fully UVC-compliant plug-and-play solution that works seamlessly on Windows, Linux, Android, and macOS with no driver installation required. Built on a high-performance 5MP color image sensor, it delivers sharp Ultra HD visuals suitable for a wide range of vision applications. The module comes equipped with a wide-angle, low-distortion M12 lens for accurate and extended scene coverage, while the onboard hardware ISP ensures consistent image quality with auto exposure, auto white balance, and other essential controls handled directly on the device.
An upgraded version B045401 is also available, featuring enhanced HDR imaging and AI-optimized resolutions for more demanding computer-vision workflows.
| General Sepcs | B045401 | B0454-1 |
| Image Sensor | ||
| Still Resolution | 5MP | 5MP |
| Color Filter Type | Color | Color |
| Shutter Type | Rolling | Rolling |
| Optical Size | 1/2.8'' | 1/4" |
| Output Format | MJPG/YUY2 | MJPG/YUY2 |
| Pixel Size | 2 µm x 2 µm | 1.4 µm x 1.4 µm |
| Sensor Active Area | 2592(H)x1944(V) | 2592(H)x1944(V) |
| Frame Rate | MJPG: 2592*1944@30fps; 2048x1536@30fps; 1920x1080@30fps; 1600x1200@30fps; 1280x960@30fps; 1280x720@30fps; 1024x768@30fps; 800x600@30fps; 640x360@30fps; 640x480@30fps; |
MJPG: 2592x1944@15fps, 2048x1536@15fps; 1600x1200@15fps, 1920x1080@30fps; 1280x960@30fps, 1280x720@30fps; 1024x768@30fps, 800x600@30fps; 640x360@30fps, 640x480@30fps; YUY2: 2592x1944@2fps, 2048x1536@2fps; 1920x1080@5fps, [email protected]; [email protected], 1280x720@10fps; 1024x768@10fps, 800x600@20fps; |
| Frame Rate(AI Resolution(YUV)) | 640x480@30fps, 320x240@30fps; 320x320@30fps, 128x128@30fps; 96x96@30fps; |
| Lens | ||
| IR Sensitivity | Integral 650nm IR Filter, visible light only | Integral 650nm IR Filter, visible light only |
| Focus Type | Fixed Focus | Fixed Focus |
| FOV | 101°(D)×88°(H)×60°(V) | 110°(D)x95°(H)x76°(V) |
| Lens Mount | M12-S | M12-S |
| F.NO | F2.8±5% | F2.5±10% |
| E.F.L | 2.7mm | 2.1mm |
| Default Focus Range | 300cm-∞ | 300cm-∞ |
| Distortion | <-1.0% | <20% |
| USB Interface | ||
| Interface | USB 2.0 Device | USB 2.0 Device |
| Connector | B4B-ZR JST | B4B-ZR JST |
| UVC Compliant | No additional drivers required | No additional drivers required |
| Electrical and Mechanical | ||
| Operating Voltage | DC 5V +/- 5% | DC 5V +/- 5% |
| Operating Temp. | 32°F-158°F (0°C to 70°C) | 32°F-158°F (0°C to 70°C) |
| Power Consumption | Typical: 1.043w | Typical: 0.818W |
| Camera Board Size | 32mm x 32mm x 1.6mm | 38mm x 38mm x 1.6mm |
| Functionality and Compatibility | ||
| HDR Support | Yes | NO |
| Enclosure | with Metal Enclosure | without Enclosure |
| Supported OS | Windows, Linux, Android | Windows, Linux, Android |
| Recommend Sample Application | Amcap for Windows, qv4l2 for Linux | Amcap for Windows, qv4l2 for Linux |
| UVC Controls | Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Lowlight Compensation, Focus (Auto/Manual), Exposure (Manual/Auto) | Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto) |
