5MP UVC Camera Module with Wide Angle M12 Lens for Windows, Linux, Android, and Mac OS
8MP A179 Autofocus USB2 UVC Camera Module with Metal Case, HDR-enabled Module Available
8MP A179 autofocus USB2 UVC camera module, available with HDR and Metal Housing Module
B0447
  • [Autofocus] Armed with standard angle excellent Autofucs Lens.
  • [Compatible with All Platforms]: Compatible with Windows, Linux, Mac, and so on.
  • [Multiple Applications]: For home surveillance system, monitoring 3D Printer, object recognition,etc..
  • [Alternative Options]: Select Upgraded Version(B044701) for HDR and Enclosure support.
$58.99
Arducam 8MP A179: 8MP USB camera module designed for high-quality imaging up to 3264×2448 resolution. With plug-and-play compatibility on Windows, Linux, Android, and macOS—no driver required—the A179 is a reliable UVC solution for applications demanding clarity, durability, and wide dynamic range.
Check upgraded version(B044701) with additional HDR support and more preset AI resolution for quick training and development of AI models, while the sturdy metal housing provides effective heat dissipation and protection.
  • 3D Scanner
  • VR Camera
  • Lightburn Laser Engraver Machine
  • Surveillance
  • Video System
[Plug-and-Play]
This 8MP camera module offers hassle-free plug-and-play operation across Windows, Linux, Android, and macOS platforms. No additional drivers or software are required—simply connect via USB and start capturing high-quality images instantly.
[AI Resolution]
Multiple preset AI image resolution. You can directly train and deploy your AI model without additional image cropping.
[Autofocus]
Featuring excellent autofocus lens, the camera automatically adjusts focus to maintain sharp and clear images across various distances, making it suitable for dynamic scenes and versatile applications.
[Upgraded Option]
Check B044701, which is equipped with High Dynamic Range (HDR) technology, Autofocus Lens, and Metal Case. Same price, better performance.
General Sepcs B044701(Upgraded) B0447-1(Standard)
Still Resolution 8MP 8MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/3.2'' 1/3.2"
Output Format MJPG/YUY2 MJPG/YUYV
Pixel Size 1.4 µm x 1.4 µm 1.4um x 1.4um
Sensor Active Area 3264(H)x2448(V) 3264(H)x2448(V)
640x480@30fps;
3264×2448@30fps, 2592×1944@30fps;
1920×1080@30fps, 1600×1200@30fps;
1280×720, 640×480@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
1280×720@10fps, 640×480@30fps;
FOV 75°(D)×61°(H)×50°(V) 63°(H)
F.NO F1.8 F2.0
E.F.L 3.95mm 3.54mm
Operating Voltage 5V 5V
Power Consumption 1.75W 1.5W
HDR Support Yes NO
Supported OS Windows, Linux Windows, Linux
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Lowlight Compensation, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
  • 1 x Arducam 8MP AF Camera Module
  • 1 x USB Cable (1m)
  • 1 x Quick start guide
