2MP AR0230 WDR USB Camera Module Manual Focus M12 Lens for Raspberry Pi, Windows, Linux, Mac OS, Android
12MP A708 USB2 UVC Camera Module, available with HDR and Metal Housing Module
5MP Autofocus USB Camera Module with Single Microphone for Windows, Linux, MacOS, Android
B0441
  • Compatible with All Platforms: Compatible with Windows, Linux, Mac, Android, and so on.
  • Plug and Play: Integrated All pre-training examples. No additional driver is needed.
  • Resolution&Frame Rate: 5MP(2592*1944)@30fps, full HD USB camera; Capture most exciting details at every 30/15fps
  • Autofocus: Armed with a 69°(HFOV) Autofocus Lens, which allows focusing at a wide range of distance.
  • Mini Sized: Designed for your embedded applications and depth sensing projects with Lightweight and compact size.
arducam shipping payment 1
$34.99
This camera is Arducam NEW Autofocus UVC camera. The max resolution&frame rate is 2592(H)×1944(V)@30fps. Besides, we have equipped the camera with Auto Focus Lens. Arducam team is committed to creating more convenient and more efficient camera solutions. We have expanded the using scope of the image sensor, enabling the camera to realize your various projects. The camera is equipped with a 69°(H) autofocus lens, allowing you to use it for more applications. It is compatible with Windows, Linux, Android and MAC. There is no additional drivers required. If you have any other requirements, please communicate with our sales team, we look forward to further cooperation with you.
  • 3D Scanner
  • VR Camera
  • Lightburn Laser Engraver Machine
  • Surveillance
  • Video System
  • Autofocus: 5MP(2592*1944)@30fps, full HD USB camera with Autofocus Lens; Capture most exciting details at every 30/15fps, FoV: 69°(H)
  • MJPEG/YUYV: Picture format MJPEG or YUY2 optional, cameras with high resolution can be used in any video system and applications for industrial.
  • Plug and Play: OTG supported just plug the USB cable into your PC’s USB port, and running the software can capture the high-level video and continuous recording, no driver is needed.
  • Compatible with All Platforms: Adopting UVC protocol, compatible with various platforms and operating systems, such as Windows, Linux, Mac, Android, etc.
  • Mini Sized: Lightweight and compact size is perfect for embedded applications, and ideal for Video systems, 3D scanners, VR cameras, electronic microscopes, and medical machines.
Resolution 5MP
Shutter Type Rolling shutter
Optical Size 1/4"
Output Format YUYV/MJPG
Pixel Size 1.4μm*1.4μm
Sensor Active Area 2592(H)×1944(V)
Frame Rate MJPG: 30fps@2592*1944/2560*1440/2048*1536/1920*1080/1280*720/1600*1200/1280* 960/800*600/640*480/352*288/176*144
YUY2:
176*144/352*288/640*480@30fps; 800*600/1280*720/1280*960/1600*1200/1920*1080@5fps;
2048*1536/2560*1440/2592*1944@2fps
Focus Type Auto Focus
FOV 69°(H)
Lens Mount M6.5*P0.25mm
F.NO 2.0±5%
E.F.L 2.46mm
Focal Length /
TV Distortion <1%
Interface USB 2.0 device
Connector SM05B-SRSS-TB
UVC Compliant no additional drivers required
Operating Voltage DC 5V +/- 5%
Working Current Max 300mA
Operating Temp. -4℉-158℉(-20°C to 70°C)
Camera Board Size 62mm x 9mm x 6mm
Audio Single Microphone
Supported OS Windows, Linux, Android and MAC
Sample Application Amcap-Windows Camera application for Video and Still Capture
UVC Controls Brightness, Contrast, Hue, Saturation, Sharpness, Gamma, White Balance, Exposure, Focus
  • 1 x Arducam 5MP AF Camera Module
  • 1 x USB Cable (1m)
  • 1 x Paper Quick start guide
