Arducam 12MP USB Camera Module with M12 Lens, 1/2.3'' 3840(H)×3032(V) 4K@15fps for Windows, Linux, MacOS and Android
5MP Autofocus USB Camera Module with Single Microphone for Windows, Linux, MacOS, Android
2MP AR0230 WDR USB Camera Module Manual Focus M12 Lens for Raspberry Pi, Windows, Linux, Mac OS, Android
B0438
  • Compatible with All Platforms: Compatible with Windows, Linux, Mac, Android, and so on.
  • Plug and Play: Integrated All pre-training examples. No additional driver is needed.
  • Resolution&Frame Rate: H.264: 25fps@1920 x 1080; MJPG: 25fps@1920 x 1080; YUY2: 25fps@640 x 360.
  • Wide-Angle Manual Focus: Armed with a 95°(HFOV) M12 Lens, which is perfect for depth sensing photography like landscape, low-light, etc.
  • Excellent Size: 38mmx38mm. Designed for hidden and narrow position for a home video surveillance system or other vision applications.
arducam shipping payment 1
was $79.99 Special Price $59.99
This camera is the Arducam NEW UVC camera.The max resolution&frame rate is 1920(H)x1080(V)@30fps. The camera is based on high-quality 2MP AR0230 WDR image sensor. Support MJPG/YUV2/H.264 output format. Besides, we have equipped an excellent Mental Case for this camera module. Arducam team is committed to creating more convenient and more efficient camera solutions. We have expanded the using scope of the image sensor, enabling the camera to realize your various projects. The camera is equipped with a 95°(H) M12 lens, allowing you to use it for more applications. It is compatible with Windows, Linux, Android and MAC and no additional drivers required. If you have any other requirements, please communicate with our sales team, we look forward to further cooperation with you.
  • 3D Scanner
  • VR Camera
  • Lightburn Laser Engraver Machine
  • Surveillance
  • Video System
  • HDR and WDR: Based on 2MP AR0230 Color COMS image sensor with a 96dB wide dynamic range. Max resolution: 1920x1080. Support MJPG/YUY2/H.264 output format.
  • HD M12 Lens: Armed with a wide angle High-quality 95-degree view angle (Horizontal) M12 Lens with 650nm IR-cut filter.
  • Manual Focus: A manual focus camera allows you to use it in situations such as macro photographs, low light, etc. where other focus type is difficult to achieve.
  • Plug & Play: UVC-compliant, support Windows XP/7/8/10, Linux, Mac OS and Andriod device with UVC, just connect the camera to PC, laptop or Raspberry Pi with the USB cable without extra drivers to be installed.
  • More Applications: This 38×38mm camera board can be installed in the most hidden and narrow position for a home video surveillance system, day-night low light vision camera system, dashcam, or other machine vision application.
Sensor AR0230
Resolution 2MP
Shutter Type Rolling shutter
Optical Size 1/2.7"
Output Format MJPG/YUY2/H.264
Pixel Size 3.0 µm x 3.0 µm
Sensor Active Area 1920(H)x1080(V)
Frame Rate MJPG 30fps@1920 x 1080/1280 x 720/640 x 480/320 x 240; YUY2 5fps@1920 x 1080/1280 x 720; 25fps@640 x 480/640 x 360/320 x 240; H.264 30fps@1920 x 1080/1280 x 720/640 x 480/640 x 360/320 x 240;
FOV 95°(H)
Lens Mount M12*P0.5
F.NO 2.8±5%
E.F.L 2.8mm
Interface USB 2.0 device
Connector B4B-ZR
UVC Compliant no additional drivers required
Operating Voltage DC 5V +/- 5%
Working Current Max 300mA
Operating Temp. -4℉-158℉(-20°C to 70°C)
Camera Board Size 38mm x 38mm x 21mm(Hole Pitch: 34mmx34mm, 28mmx28mm)
Audio /
Supported OS Windows, Linux, Android and MAC
Sample Application Amcap-Windows Camera application for Video and Still Capture
UVC Controls Brightness, Contrast, Hue, Saturation, Sharpness, Gamma, White Balance (Auto), Backlight Contrast, Gain, Exposure (Auto)
  • 1 x Arducam 2MP USB Camera Module with M12 Lens
  • 1 x USB Cable (1M)
  • 1 x Quick Start Guide
