Arducam IMX298 MIPI 16MP Color Camera Module for Raspberry Pi 4/3B+/3
4mm Manual Focus USB Camera with 1/2.7
4mm Manual Focus USB Camera with 1/2.7" AR0230 Image Sensor, Full HD 1080P HDR Webcam with CCTV Video Lens for Android, Linux, Windows, and Mac OS-Arducam
8MP 1080P Wide Angle USB Camera with Mini Metal Case, 1/3.2” CMOS IMX179 UVC USB2.0 Webcam Board with M12 Lens, Microphone, 3.3ft/1m Cable for Windows, Linux, Android, and Mac OS-Arducam
UB022901
$59.99
The UB022901 is a new member of Arducam’s USB camera family. It’s an 8MP, UVC compliant, wide angle, M12 USB 2.0 camera.
  • More than HD: This camera adopts an 8MP IMX179 sensor for sharp images and accurate color reproduction.
  • Wide Angle: High-quality 105-degree view angle (diagonal) M12 lens with IR filter, which provides a much wider Field of View.
  • Plug&Play: UVC-compliant, just connect the camera to a PC computer, laptop, Android device, or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Capture Video with Audio: High frame rates, MJPG 15fps@3264 x 2448, 30fps@1080P; YUY2 30fps@640x 480; Audio, single microphone (optional dual channels).
  • Applications: Comes with a metal case and rotatable bracket, this tiny camera can be installed in a narrow position, highly recommended for monitoring Octoprint 3D Printer, a home video surveillance system and other vision applications demand high resolution.
- Sensor: 1/3.2” IMX179
- Resolution: 8MP 3264H x 2448V
- Data Format: MJPG/YUY2
- Frame Rate: MJPG 15fps@3264 x 2448, 30fps@1080P; YUY2 30fps@640x 480
- Field of View (FOV):105°(D)
- Lens Mount: M12
- IR Sensitivity: Integral IR filter, visible light only Functionality and Compatibility
- Adjustable parameter: Brightness, Contrast, Saturation, Hue, Sharpness, Gamma, Gain, White balance, Exposure.
- Audio: Single microphone (optional dual channels)
- System Compatibility: Windows, Linux, Mac, and Android with UVC. Power
- Working Current: MAX 350mA Physical
- Dimension: 40mmx28mmx45mm
- Cable Length: 3.3ft (1M)
Manual.pdf
Manual.pdf
