8MP HDR Autofocus USB Camera Module with Metal Housing, 1080P Mini UVC USB2.0 Webcam, A219
8MP Autofocus USB Camera Module with Microphone with Metal Housing, 1080P Mini UVC USB2.0 Webcam, A219
B029201-1
  • [High Resolution] 8MP HD, Max resolution: 3264*2448
  • [Autofocus] Armed with a 72° (DFOV) Autofocus Lens.
  • [Microphone] Equipped with single microphone for audio.
$38.99
An 8MP USB camera module with autofocus and a built-in microphone, offering high-resolution imaging up to 3264×2448 and smooth 1080P video over USB 2.0. Featuring a 72° DFOV autofocus lens, it ensures clear and wide-angle captures. With plug-and-play compatibility across Windows, Linux, Android, and macOS, it’s an ideal solution for surveillance, 3D printing, security, and other embedded vision applications. This is with a metal housing.
Application
  • Robotics
  • Precision Agriculture
Feature
  • [High Resolution]
    This 8MP HD camera module delivers crisp and detailed images with a maximum resolution of 3264 × 2448 pixels, ensuring high-quality visuals suitable for a variety of professional and embedded applications.
  • [Plug-and-Play]
    Designed for maximum convenience, the camera supports true plug-and-play across Windows, Linux, Android, and macOS platforms. No additional drivers are needed—simply connect via USB and start capturing right away.
  • [Autofocus]
    Equipped with a wide 72° diagonal field of view (DFOV) autofocus lens, the camera automatically adjusts focus to maintain sharp images even as subject distance varies, providing clear, reliable performance in dynamic environments.
  • [Microphone]
    The integrated single microphone captures clear audio to complement video recordings, making it suitable for multimedia, conferencing, security, and other applications requiring synchronized sound and visuals.
  • [Metal Case]
    The sturdy metal housing enhances heat dissipation and protects the internal components, ensuring stable operation and durability during long-term use or in demanding conditions.
General Sepcs B029202C B029201-1
Still Resolution 8MP 8MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/4" 1/4"
Sensor Active Area 3280(H)×2464(V) 3280(H)×2464(V)
640x480@30fps;
3264x2448@15fps, 2592x1944@15fps;
640x480@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
640x480@10fps, 320x240@10fps;
FOV 75°(D)×61°(H)×50°(V) 72°(D)×60°(H)×47°(V)
F.NO F1.8 F2.0
E.F.L 3.95mm 2.96mm
Operating Voltage 5V 5V
Power Consumption 1.75W 1W
Camera Board Size 32mm x 32mm x 1.6mm 38mm x 38mm
HDR Support YES NO
Enclosure with Metal Enclosure with Metal Enclosure
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Lowlight Compensation, Gain, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
