8MP Autofocus USB Camera Module with Microphone with Metal Housing, 1080P Mini UVC USB2.0 Webcam, A219
12MP USB UVC Fixed-Focus Camera Module, A708
8MP HDR Autofocus USB Camera Module with Metal Housing, 1080P Mini UVC USB2.0 Webcam, A219
B029202C
  • [HDR] Features the High Dynamic Range function.
  • [Autofocus] Armed with a 72° (DFOV) Autofocus Lens.
  • [High Resolution] 8MP HD, Max resolution: 3264*2448
$38.99
An compact 8MP USB camera module with HDR and autofocus, housed in a durable metal case for enhanced heat dissipation and protection. It delivers high-resolution imaging up to 3264×2448 and 1080P video over USB 2.0, with a 72° DFOV autofocus lens for wide-angle clarity. With plug-and-play support on Windows, Linux, Android, and macOS, the A219 is a reliable choice for embedded vision applications requiring sharp detail and strong dynamic range.
  • Robotics
  • Precision Agriculture
  • [Plug-and-Play]
    This camera module offers effortless plug-and-play connectivity across Windows, Linux, Android, and macOS platforms. No extra drivers or software installations are required—just connect via USB and begin capturing high-quality images immediately.
  • [HDR]
    Equipped with High Dynamic Range (HDR) technology, the camera delivers balanced images with enhanced detail in both bright and dark areas. This ensures clear and vivid visuals even in challenging lighting conditions.
  • [Autofocus]
    Featuring a 72° diagonal field of view (DFOV) autofocus lens, the camera automatically adjusts focus to maintain sharp and clear images across various distances, making it suitable for dynamic scenes and versatile applications.
  • [High Resolution]
    With an 8MP sensor capable of capturing still images up to 3264 × 2448 pixels, the camera provides high-definition visuals ideal for detailed inspection, monitoring, and embedded vision tasks.
  • [Metal Case]
    Housed in a robust metal enclosure, the camera benefits from effective heat dissipation and enhanced durability. The metal case ensures reliable performance and product integrity during extended use or in demanding environments.
General Sepcs B029202C B029201-1
Still Resolution 8MP 8MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/4" 1/4"
Sensor Active Area 3280(H)×2464(V) 3280(H)×2464(V)
640x480@30fps;
3264x2448@15fps, 2592x1944@15fps;
640x480@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
640x480@10fps, 320x240@10fps;
FOV 75°(D)×61°(H)×50°(V) 72°(D)×60°(H)×47°(V)
F.NO F1.8 F2.0
E.F.L 3.95mm 2.96mm
Operating Voltage 5V 5V
Power Consumption 1.75W 1W
Camera Board Size 32mm x 32mm x 1.6mm 38mm x 38mm
HDR Support YES NO
Enclosure with Metal Enclosure with Metal Enclosure
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Lowlight Compensation, Gain, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
