8MP HDR Autofocus USB Camera Module with Metal Housing, 1080P Mini UVC USB2.0 Webcam, A219
12MP HDR USB UVC Autofocus Camera Module with Metal Housing, A708
12MP USB UVC Fixed-Focus Camera Module, A708
B0304-1
  • [High Resolution] 12MP, Max resolution: 4608 × 2592
  • [Fixed Focus] Equipped with High-Quality Fixed Focus Lens. Integral 650nm IR-cut filter.
  • [Microphone] Equipped with single microphone for audio.
  • [Rich Applications] Can be applied in surveillance systems, 3D Printing, security systems, and so on.
arducam shipping payment 1
$59.98
A 12MP USB camera module with a high-quality fixed-focus lens and built-in microphone, delivering sharp images up to 4608×2592 resolution. It features an integrated 650nm IR-cut filter for accurate color reproduction and supports plug-and-play use on Windows, Linux, Android, and macOS with no driver installation needed. Ideal for surveillance, 3D printing, and security applications, the A708 offers reliable performance in a compact UVC-compliant design.
  • Robotics
  • Precision Agriculture
  • [High Resolution]
    This 12MP camera module delivers sharp and detailed images with a maximum resolution of 4608 × 2592 pixels, ensuring clear and precise visuals suitable for a wide range of applications.
  • [Plug-and-Play]
    Designed for easy integration, the camera supports true plug-and-play functionality across Windows, Linux, Android, and macOS platforms without the need for additional drivers or software installations.
  • [Fixed Focus]
    Equipped with a high-quality fixed-focus lens, the module provides consistent sharpness at a predetermined focal range, simplifying setup and ensuring reliable image clarity. An integral 650nm IR-cut filter enhances color accuracy by filtering out infrared light.
  • [Microphone]
    A built-in single microphone captures clear audio, complementing video recordings for applications such as security monitoring and multimedia communication.
    This versatile camera module is ideal for use in surveillance systems, 3D printing monitoring, security systems, and other embedded vision projects where reliable image and audio capture are essential.
General Sepcs B030401 B0304-1
Still Resolution 12MP 12MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/2.43" 1/2.43"
Output Format MJPG/YUY2 MJPG
Pixel Size 1.4µm x 1.4µm 1.4um x 1.4um
Sensor Active Area 4608(H)x2592(V) 4608(H)x2592(V)
Frame Rate(MJPG) 4608x2592@15fps, 3840x2160@25fps;
3264x2448@25fps, 2592x1944@30fps;
1920x1080@30fps,1280x720@30fps;
640x480@30fps;
4608x2592@10fps, 2304x1296@30fps;
1920x1080@30fps, 1600x1200@30fps;
1280x720@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
Focus Type Autofocus Fixed Focus
FOV 75°(D)×61°(H)×50°(V) 75°(D)x66°(H)x41°(V)
F.NO F1.8 F1.8
E.F.L 3.95mm 4.74mm
Default Focus Range 10cm-∞ 150cm-∞
Operating Voltage 5V 5V
Power Consumption Max: 1.75W Max: 1.5W
Camera Board Size 32mm x 32mm x 1.6mm 24mm x 25mm
HDR Support YES NO
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Lowlight Compensation, Gain, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
  • 1 x Arducam IMX708 Fixed Focus Camera Module with UVC adapter board
  • 1 x USB2.0 Cable (1m/3.3ft)
  • If you can't capture the images using Amcap, please try other software such as USB Camera, PotPlayer, etc.
