[Discontinued] 2MP AR0230 WDR USB Camera Module with Metal Case and M12 Lens for Raspberry Pi, Windows, Linux, Mac OS, Android
[Discontinued] 2MP IMX290 Color Ultra Low Light STARVIS WDR Camera Module with M12 Lens for Raspberry Pi
[Discontinued] 2MP IMX327 Color Ultra Low Light STARVIS WDR Camera Module with M12 Lens for Raspberry Pi
B0442
Discontinued, Check alternative camera B0444.
  • Ultra Low Light: Ultra low light Sony STARVIS IMX327 image sensor. Supports capturing images in extremely low light conditions(even 0 Lux)
  • Replaceable M12 Lens: Equipped with a 88°(HFOV) M12 Lens. You can replace it with other M12 lenses. Example Lenses: LK005
  • Platform Compatibility: Supports Raspberry Pi 3/4/Zero/CM3/CM4. Native to Raspberry Pi. No additional driver is needed.
  • Higher Frame Rate: 90fps at 1280×720 resolution, 46fps at 1920×1080. Maximum frame rate in Full HD 1080p mode: 30 fps
  • Cost-effective: second-to-none choice for performance and cost. Low power consumption and Low cost of price with high performance.
$27.99
The ultra low light image sensor can receive more light in extremely low light conditions, making it widely applicable to special lighting projects such as astrophotography. This camera is based on the SONY IMX327 STARVIS Ultra low light image sensor. The sensor has very high perfomance for better image quality in low-light environments. It features low power consumption and high functionality and applies R, G, and B primary color mosaic filters, as well as a variable electronic shutter.
The camera is equipped with a 88°(HFOV) M12 Lens. A manual focus camera allows you to use it in situations such as macro photographs, low light conditions, etc. Meanwhile, this camera is native to Raspberry Pi and fully supported by libcamera and Picamera2 library.
  • Astrophotography
  • Surveillance cameras
  • FA cameras
  • Ultra Low Light: Based on Sony STAVIS Ultra Low Light IMX462 image sensor, which is capable of capturing visible and near-infrared images with very low noise even in extremely low-light conditions or no light (near 0 lux).
  • High G Sensitivity: Up to 10471 G sensitivity and ~1 NIR sensitivity. Higher the G sensitivity, better is the low light performance. High NIR sensitivity also enables it to accept more of the near-infrared spectrum, improving image quality under special lighting conditions
  • Quality Images/Videos: Up to 90fps at 1280x720 resolution, 46fps at 1920x1080 in still mode. Maximum frame rate in Full HD 1080p mode: 30 fps. Support Multiple exposure WDR, Digital Overlay WDR with clear image and higher signal-to-noise ratio.
  • Native to Raspberry Pi: Compatible with Raspberry Pi 3/4/Zero/CM3/CM4. Native to Raspberry Pi. No additional driver is need. Support latest Raspberry Pi Bullseye OS and libcamera command.
  • Cost-Effective: Second-to-none choice for performance and cost. It features low power consumption and high functionality which can achieve high sensitivity, low dark current and no smear.
Image Sensor IMX327
Resolution 2MP
Optical Size 1/2.8''(6.46mm sensor diagonal)
Number of effective pixels 1920(H) × 1080(V)
Pixel Size 2.9μm × 2.9μm
Support Platform Raspberry Pi 4/3/Zero/CM3/CM4
Shutter Type Rolling Shutter
Color Filter Array Quad-Bayer RGB
Frame Rate RAW10:1920x1080@46fps;1280x720@90fps
RAW12:1920x1080@46fps;1280x720@90fps
Output Format RAW10/RAW12
Focal Length 3.6mm
Lens Size (2G2P+IR) M12 Lens
Field of View(FOV) 120°(D)x88°(H)x55°(V)
Camera Board Size 38 × 38 × 20.67mm
  • 1 x Arducam 2MP IMX327 Ultra Low Light camera module with M12 Lens
  • 1 x 150mm 15pin-22pin FPC Cable
  • This camera is native supported by Raspberry Pi, you don't need additional driver to run it, but you will need some configuration, please refer to the following doc.
