[Discontinued] 2MP IMX327 Color Ultra Low Light STARVIS WDR Camera Module with M12 Lens for Raspberry Pi
[Discontinued] 2MP IMX462 Color Ultra Low Light STARVIS HDR Camera Module with M12 Lens for Raspberry Pi
[Discontinued] 2MP IMX290 Color Ultra Low Light STARVIS WDR Camera Module with M12 Lens for Raspberry Pi
B0408
Discontinued, check alternative item B0444
  • Ultra Low Light: Ultra low light Sony STARVIS IMX290 image sensor. Supports capturing images in extremely low light conditions(even 0 Lux)
  • Replaceable M12 Lens: Equipped with a 88°(HFOV) M12 Lens. You can replace it with other M12 lenses. Example Lenses: LK005
  • Platform Compatibility: Supports Raspberry Pi 3/4/5/Zero/CM3/CM4. Native to Raspberry Pi. No additional driver is needed.
  • Higher Frame Rate: 90fps at 1280×720 resolution, 46fps at 1920×1080. Maximum frame rate in Full HD 1080p mode: 30 fps
  • Cost-effective: second-to-none choice for performance and cost. Low power consumption and Low cost in price with high performance.
arducam shipping payment 1
$29.99
The ultra low light image sensor can receive more light in extremely low light conditions, making it widely applicable to special lighting projects such as astrophotography. This camera is based on the SONY IMX290 STARVIS Ultra low light image sensor. The sensor has very high performance for better image quality in low-light environments. It features low power consumption and high functionality and applies R, G, and B primary color mosaic filters, as well as a variable electronic shutter.
The camera is equipped with a 88°(HFOV) M12 Lens. A manual focus camera allows you to use it in situations such as macro photographs, low light conditions, etc. Meanwhile, this camera is native to Raspberry Pi and fully supported by libcamera and Picamera2 library.
Arducam is committed to creating diverse and convenient camera solutions for embedded camera users. We are not only engaged in the production and development of optical products, but also strive to provide complete solutions for embedded cameras, optical components, etc. For details, please refer to our official website www.arducam.com
  • Astrophotography
  • Surveillance cameras
  • FA cameras
  • Ultra Low Light: Based on Sony STAVIS Ultra Low Light IMX290 image sensor. The chip uses analog 2.9 V, digital 1.2 V, and interface 1.8 V. This highly sensitive low-light camera can capture extremely sharp images with minimal noise at extremely low light conditions.
  • Quality Images/Videos: Up to 90fps at 1280x720 resolution, 46fps at 1920x1080 in still mode. Maximum frame rate in Full HD 1080p mode: 30 fps. Support Multiple exposure WDR, Digital Overlay WDR with clear image and higher signal-to-noise ratio.
  • Platform Compatibility: Supports Raspberry Pi 3, 4 A/B, 5, and CM3/CM4, equipped with 15-22pin FPC flexible cable. Supports application on Raspberry Pi Zero (22-pin FFC flexible cable not included in the package).
  • Native to Raspberry Pi: Native to Raspberry Pi. No additional driver is needed. You just need to execute some modifications in the config file.
  • Cost-Effective: Second-to-none choice for performance and cost. It features low power consumption and high functionality which can achieve high sensitivity, low dark current and no smear.
Image Sensor IMX290
Resolution 2MP
Optical Size 1/2.8''(6.46mm sensor diagonal)
Number of effective pixels 1920(H) × 1080(V)
Pixel Size 2.9μm × 2.9μm
Support Platform Raspberry Pi 5/4/3/Zero/CM3/CM4
Shutter Type Rolling Shutter
Color Filter Array Quad-Bayer RGB
Frame Rate RAW10:1920x1080@46fps;1280x720@90fps
RAW12:1920x1080@46fps;1280x720@90fps
Output Format RAW10/RAW12
Focal Length 3.6mm
Lens Size (2G2P+IR) M12 Lens
Field of View(FOV) 120°(D)x88°(H)x55°(V)
Camera Board Size 38 × 38 × 20.67mm
  • 1 x Arducam 2MP IMX290 Ultra Low Light camera module with M12 Lens
  • 1 x 150mm 15pin-22pin FPC Cable
  • This camera is native supported by Raspberry Pi, you don't need additional driver to run it, but you will need some configuration, please refer to the following doc.
  • The lens on this camera is not interchangeable, if you need to replace the lens, please contact sales in advance!
    Raspberry Pi 5 √ √
