16MP Autofocus USB Camera with Microphone, 1/2.8
16MP Autofocus USB Camera with Microphone, 1/2.8" Mini UVC USB2.0 4K Video Webcam, A298
16MP Autofocus USB Camera with Metal Housing, 1/2.8
16MP Autofocus USB Camera with Metal Housing, 1/2.8" Mini UVC USB2.0 4K Video Webcam, A298
B029002
  • [High Quality Imaging] 16MP for sharp image with still picture resolution at 4656 x 3496 Max.
  • [Autofocus] Armed with a 60° (HFOV) Autofocus Lens.
  • [AI Resolution] Multiple preset AI image resolution for directly training and deploying AI model.
$49.99
A compact 16MP USB camera module featuring a durable metal housing, 1/2.8" sensor, and autofocus lens with a 60° field of view. It delivers high-resolution still images up to 4656×3496 and smooth 4K video over USB 2.0, all with plug-and-play support on Windows, Linux, Android, and macOS—no drivers needed. The built-in digital PTZ (Pan-Tilt-Zoom) enables ROI control at lower resolutions, making it a versatile solution for applications like surveillance, inspection, and automation.
  • [High Quality Imaging] This 16MP camera module delivers exceptionally sharp and detailed images, with a maximum still picture resolution of 4656 × 3496 pixels. It’s designed to meet the needs of applications requiring precise and clear imaging.
  • [Plug-and-Play] Offering seamless compatibility across Windows, Linux, Android, and macOS, the camera supports true plug-and-play functionality with no additional drivers required. Just connect via USB and start capturing high-quality images and video immediately.
  • [Autofocus] Equipped with a 60° horizontal field of view (HFOV) autofocus lens, the camera automatically maintains sharp focus as subjects move or change distance, ensuring consistently clear visuals without manual adjustment.
  • [AI Resolution] Multiple preset AI image resolution. You can directly train and deploy your AI model without additional image cropping.
  • [Metal Case] Housed in a durable metal enclosure, the camera benefits from excellent heat dissipation and mechanical protection. The robust metal case ensures reliable performance and longevity, even under extended use or challenging operating conditions.
  • Robotics
  • Precision Agriculture
General Sepcs B029002 B0290-1
Still Resolution 16MP 16MP
Color Filter Type Color Color
Shutter Type Rolling Rolling
Optical Size 1/2.8'' 1/2.8"
Sensor Active Area 4656(H) x 3496(V) 4656(H) x 3496(V)
Frame Rate(MJPG) 4656x3496@10fps, 4000x3000@15fps;
3840x2160@25fps, 3264x2448@25fps;
2592x1944@30fps, 1920x1080@30fps;
1280x720@30fps, 640x480@30fps;
4656x3496@10fps, 3840x2160@10fps;
, 2592x1944@10fps, 1920x1080@30fps;
1280x720@30fps;
320x320@30fps, 128x128@30fps;
96x96@30fps;
640×480@20fps, 320x240@30fps;
FOV 75°(D)×61°(H)×50°(V) 60°(H)
F.NO F1.8 /
E.F.L 3.95mm /
Operating Voltage 5V 5V
Power Consumption 1.75W 1W
HDR Support NO NO
UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
UVC Camera Module Datasheet.pdf Manual.pdf 3D drawing.STEP
  • 1 × 16MP IMX298 USB 2.0 camera board
