16MP Autofocus USB Camera with Metal Housing, 1/2.8
16MP Autofocus USB Camera with Metal Housing, 1/2.8" Mini UVC USB2.0 4K Video Webcam, A298
8MP Autofocus USB Camera Module with Microphone, 1080P Mini UVC USB2.0 Webcam, A219
B029002C
  • [High Quality Imaging] 16MP for sharp image with still picture resolution at 4656 x 3496 Max.
  • [Autofocus] Armed with a 60° (HFOV) Autofocus Lens.
  • [AI Resolution] Multiple preset AI image resolution for directly training and deploying AI model.
  • $51.99
    A compact 16MP USB camera module featuring a durable metal housing, 1/2.8" sensor, and autofocus lens with a 60° field of view. It delivers high-resolution still images up to 4656×3496 and smooth 4K video over USB 2.0, all with plug-and-play support on Windows, Linux, Android, and macOS—no drivers needed. The built-in digital PTZ (Pan-Tilt-Zoom) enables ROI control at lower resolutions, making it a versatile solution for applications like surveillance, inspection, and automation.
    Feature
    • [High Quality Imaging] This 16MP camera module delivers exceptionally sharp and detailed images, with a maximum still picture resolution of 4656 × 3496 pixels. It’s designed to meet the needs of applications requiring precise and clear imaging.
    • [Plug-and-Play] Offering seamless compatibility across Windows, Linux, Android, and macOS, the camera supports true plug-and-play functionality with no additional drivers required. Just connect via USB and start capturing high-quality images and video immediately.
    • [Autofocus] Equipped with a 60° horizontal field of view (HFOV) autofocus lens, the camera automatically maintains sharp focus as subjects move or change distance, ensuring consistently clear visuals without manual adjustment.
    • [AI Resolution] Multiple preset AI image resolution. You can directly train and deploy your AI model without additional image cropping.
    • [Metal Case] Housed in a durable metal enclosure, the camera benefits from excellent heat dissipation and mechanical protection. The robust metal case ensures reliable performance and longevity, even under extended use or challenging operating conditions.
    • Robotics
    • Precision Agriculture
    General Sepcs B029002C B029001-1
    Still Resolution 16MP 16MP
    Color Filter Type Color Color
    Shutter Type Rolling Rolling
    Optical Size 1/2.8'' 1/2.8"
    Sensor Active Area 4656(H) x 3496(V) 4656(H) x 3496(V)
    Frame Rate(MJPG) 4656x3496@10fps, 4000x3000@15fps;
    3840x2160@25fps, 3264x2448@25fps;
    2592x1944@30fps, 1920x1080@30fps;
    1280x720@30fps, 640x480@30fps;
    4656x3496@10fps, 3840x2160@10fps;
    , 2592x1944@10fps, 1920x1080@30fps;
    1280x720@30fps;
    320x320@30fps, 128x128@30fps;
    96x96@30fps;
    640×480@20fps, 320x240@30fps;
    FOV 75°(D)×61°(H)×50°(V) 60°(H)
    F.NO F1.8 /
    E.F.L 3.95mm /
    Operating Voltage 5V 5V
    Power Consumption 1.75W 1W
    HDR Support NO NO
    Enclosure with Metal Enclosure with Metal Enclosure
    UVC Controls Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto) Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto)
