A USB 3 camera evaluation kit with a 108MP camera module and our USB 3.0 camera adapter for you to build quick prototypes and proofs-of-concept with any backend hardware.
The dev kit also comes with a complete SDK you can reply on to make easy integration into any machine vision applications.
Yes, but we highly recommend using our high-res Pi/Jetson camera series.
Can I use custom resolutions & frame rates?
Yes.
Does it support H.264/H.265 encoding?
It depends on the hardware you are using the camera kit with.
