Arducam 1MP OV10633 1/3'' CMOS WDR sensor Standalone Camera UC10633-A46
Arducam 2MP OV2655 1/5
Arducam 2MP OV2655 1/5"CMOS sensor Standalone Camera UC2655-A24
Arducam 1MP NT99141 1/4'' HD Color CMOS Sensor OEM Camera Module UC99141-A
U6044
  • USB 3.0 quick development?and evaluation board for sensors like NT99141.
  • Still Picture Resolution: HD 1280 x 720, support any size scaling down.
  • Frame Rate: 640 x 360 @ 60fps, HD (1280 x 720) @ 30fps
  • Size: 20.87 x 12.5 x 6.35 mm, neck width is 6mm
  • Power Supply: Digital 1.5V, analog 3.3V, I/O 1.8V/2.8V
  • Mating Connector: FH52E-24S-0.5SH(99)
$7.00
To meet the requirement of the mini camera size for some space or weight constrained application, Arducam now released an OEM camera module series Standalone, which combines the PCB into the camera cable to shrink the camera module greatly.
This U6044 is based on 1/4'' NT99141 HD CMOS sensor, adopts a fixed-focus lens and 6mm width flex cable, and you can read more about its specs in the next chapter.
  • Notebook and Desktop PC cameras
  • Toys
  • Digital still cameras and camcorders
  • Video telephony and conferencing equipment
  • Security System
  • Bar code reader
  • Low dark current
  • Auto black level calibration
  • Two-wire serial interface, 16-bit address, and 8-bit data
  • Support output format: YCbCr (4:2:2), RGB565, RGB555,RGB444,Raw,CCIR656, and JPEG also.
  • Support image size: HD (1280*720), and any size scaling down.
  • Lens shading correction and Defect pixel correction.
  • Automatic control functions: Auto-Exposure control (AE), Auto-White Balance (AWB)
  • Including: Sharpness, noise reduction, defect correction, gamma, color saturation adjust.
  • Special effects included.
  • Anti-Shake
  • Embedded 1.5V regulator for core power
  • Target module size: 8*8mm
Key Specifications
Items Parameter Value
Sensor Sensor Type 1/4" NT99141
Array Size 1288 × 728
Pixel Size 3.0 μm × 3.0 μm
Image Area 3864 μm × 2184 μm
Frame Rate 640 x 360 @ 60fps
Lens ELF: 2.8mm 2.8mm
F.NO: 2.8 2.8
View Angle 68°
Distortion <1.0%
Power Supply Digital 1.5V
Analog 1.8V/2.8V
I/O 3.3V
Interface Interface Type DVP
Mating Connector FH52E-24S-0.5SH(99)
Dimension Lens Dimension 8 x 8 x 6.35 mm
Module Dimension 20.87 x 12.5 mm
Arducam now offers the stand-alone camera modules for customer who put these cameras into their products like toys, robots, drones and etc. Users don’t need to handle with the tiny and fine pin pitch sensor chip and small plastic lens, just take it for granted. The camera resolution is ranging from 0.3MP to 16MP with […]
U6044 Product Drawing
