The store will not work correctly when cookies are disabled.
JavaScript seems to be disabled in your browser.
For the best experience on our site, be sure to turn on Javascript in your browser.
NEW
Arducam IMX900 Series Camera Module —
Stereo · USB · GMSL Multi-Cam ,
built for Robotics , 3D Capture & In-Vehicle Vision .
Shop the Series
Arducam 0.3MP 1/4'' CMOS Sensor Standalone Camera UC7725-A
Arducam 1MP NT99141 1/4'' HD Color CMOS Sensor OEM Camera Module UC99141-A
Arducam 1MP OV10633 1/3'' CMOS WDR sensor Standalone Camera UC10633-A46
Application:
Surveillance
Cellular and picture phones
Toys
PC multimedia
Digital still cameras
Details
Support for image sizes: HD 720p (1280 * 720), WVGA (752 * 480), VGA (640 * 480), 600 * 400, CIF (352 * 288), QVGA (320 * 240)
Support for output formats: YUV and separated and combined RAW
Parallel DVP interface
High sensitivity
Automatic exposure/gain
Horizontal and vertical windowing capability
Auto white balance control
Aperture/gamma correction
Serial camera control bus (SCCB) for register programming
Low power consumption
External frame sync capability
50/60 Hz flicker cancellation
Defective pixel correction
Active array size: 1280 * 720
Power supply: analog 3.14~3.47V, core 1.6~1.7V, I/O 1.7~3.47V
Power requirements:
Active: 532 mW typical @ 3.3V AVDD,1.65V DVDD,and 1.8V DOVDD, standby 480 uW typical @ 3.3V AVDD, 1.65V DVDD, and 1.8V DOVDD
Temperature range: operating -20℃ to 85℃ junction temperature (see table 8-2)
stable image: 0℃ to 50℃ junction temperature
Output interfaces: 10-bit parallel DVP
Output formats: up to 18-bit combined raw, separated 10-bit raw, 8-/10-bit YUV422
Lens size: 1/3"
Lens chief ray angle: 9° (see figure 10-2)
Input clock frequency: 6~27 MHz
Scan mode: progressive
Shutter: rolling shutter
Maximum exposure interval: 828 tROW
Maximum image transfer rate: 30 fps full resolution
Sensitivity: 3650 mV/Lux-sec
Max S/N ratio: 39 dB
Dynamic range: 115 dB
Pixel size:4.2 um * 4.2 um
Dark current: 2.5 mV/sec @ 50℃ junction temp
Image aera: 5510.4 um * 3418.8 um
Package dimensions: 11 mm * 11 mm
