Output support for Raw RGB,RGB (GRB 4:2:2, RGB565/555/444) and YCbCr (4:2:2) formats
Supports image sizes: VGA, QVGA, and any size scaling down from CIF to 40 * 30
VarioPixel® method for sub-sampling
Automatic image control functions including Automatic exposure control (AEC), automatic gain control (AGC), automatic white balance (AWB),
automatic band filter (ABF), and automatic black-level calibration (ABLC)
Image quality controls including color saturation, hue, gamma, sharpness (edge enhancement), and anti-blooming
ISP includes noise reduction and defect correction
Lens shading correction
Saturation level auto adjust (UV adjust)
Edge enhancement level auto adjust
De-noise level auto adjust
Frame synchronization capability
Key Specifications
Array size: 640 * 480
Power supply: digital core 1.8VDC ± 10%, analog 3.0V to 3.6V, I/O 1.7V to 3.3V
Power requirements: active 120 mW typical (60 fps VGA,YUV),standby < 20 uA
Temperature range: -20℃ to +70℃
Output format: 8-bit (YUV/YCbCr 4:2:2 @ RGB565/555/444 @ GRB 4:2:2 @ Raw RGB data), 10-bit Raw RGB data
Lens size: 1/4"
Lens chief ray angle: 25° non-linear
Max image transfer rate: 60 fps for VGA
Sensitivity: 3.0V/(Lux • sec)
S/N Ratio: 50dB
Dynamic range: 60 dB
Scan mode: Progressive
Electronic exposure: up to 510:1 (for selected fps)
Pixel size: 6.0 um * 6.0 um
Dark current: 40 mV/s
Well capacity: 26Ke-
Fixed pattern noise: <0.03% of VPEAK-TO-PEAK
Image area: 3984 um * 2952 um
Package dimensions: 5345 um * 5265 um
