To help customers evaluate the cameras or build a prototype with your own circuits without dealing with fine pin pitch flex cable or soldering balls, Arducam has released the evaluation kit with camera breakout boards and Arducam USB2/USB3 camera shield without writing a single line of code.
The camera evaluation kit is based on a 5MP high resolution image sensor and equipped with a fixed focus Lens. Meanwhile, accompanied by Arducam USB Camera Shield UI tools, it can achieve the adjustment of white balance, exposure, gain, and so on.
It comes with a 5MP camera module and our USB 3.0 camera adapter for you to build quick prototypes and proofs-of-concept with any backend hardware. The dev kit also comes with a complete SDK you can rely on to make easy integration into any machine vision applications. Arducam is committed to creating diverse and convenient camera solutions. For details, please refer to our official website www.arducam.com
| Specs | |
| Resolution/Frame Rate | 2592x1944@6fps,1920x1080@6fps, 1600x1200@6fps,1280x720@25fps, 640x480@30fps,320x320@30fps, 320x240@30fps,128x128@30fps, 96x96@30fps |
| Sensor Output Format | JPG/YUV/RGB |
| Exposure Control Range | - |
| Gain Control Range | - |
| Focus Control Range | - |
| Focal Length | 2.46 |
| Field of View(FOV) | 88°(D)×75(H)×60°(V) |
| F.NO | F2.0±5% |
| Focus Type | Fixed Focus |
| Power Consumption* | Max: 5V/338mA |
| Operation Temperature | 0-50 ℃ |
| Evaluation Kit Size | 40mmx40mm |
| Functions | |
| Image File Format | - |
| Software ISP | - |
| Supported Programming Languages | Python/C++ |
| Supported OS | Windows x86/x86_64 |
| GUI(Graphical User Interface) | Supported |
| Optional Items | |
| Random Resolution | These additional functions require customized services to be supported. Please contact sales for customization services. |
| Even Higher/Lower Frame Rate | |
| More RAW Output Format Options(RAW10) | |
| Long Exposure | |
| External Trigger Mode | |
