Raspberry Pi Camera Module 3 is the latest camera model released by Raspberry Pi Official in 2023. The camera adopts Sony 11.9MP IMX708 Image Sensor which can be used to take full HD video as well as stills photographs, and features an HDR mode up to 3 megapixels.
The camera integrates IR-cut filter and adopts Phase Detection Autofocus. It is fully supported by the libcamera and Picamera2 library. Camera Module 3 is compatible with all Raspberry Pi computers.
Arducam is committed to creating diverse and convenient camera solutions. We designed various accessories for the Raspberry Pi Camera Module 3. Among them, the Arducam camera enclosure case is fully compatible with Raspberry Pi V1/V2/V3 and Arducam 16MP/64MP cameras.
Wildlife Photograph
Learning Camera
High-Quality Monitor
AI applications
Vision Transition Project
Raspberry Pi Official Camera Module 3: Raspberry Pi Camera Third Generation: Back-illuminated and stacked CMOS 12MP high resolution Image Sensor (Sony IMX708) with HDR mode for up to 3-megapixel output
High-quality Images: Max Resolution: 4608 × 2592. Along with built-in 2D DPC and QBC Re-mosaic function, offering High signal-to-noise ratio (SNR)
PDAF&CDAF System: Mixture of Phase Detection Autofocus and Contrast Detection Autofocus . By reserving PDAF and CDAF pixels on the photosensitive element, then the offset value of the focus is calculated from the phase difference and check the highest contrast to achieve accurate focusing
MIPI CSI-2 Communication: MIPI CSI-2 2-wire serial communication (supports I2C fast mode and fast mode plus) and 2-wire serial control of focus mechanism
Acrylic Case: Arducam camera enclosure case designed for 25*24mm, v1/v2, and the official camera module V3 boards (Standard, Wide, NoIR and NoIR Wide).
