Arducam 5MP OG05B10 Color Global Shutter USB 3.0 Camera-Without Enclosure
Arducam 5MP OG05B1B Mono Global Shutter USB 3.0 Camera-Without Enclosure
Arducam 5MP OG05B1B Mono Global Shutter USB 3.0 Camera-With Enclosure
B0538C
  • Mono global shutter camera with high sensitivity, low noise, and enhanced NIR performance.
  • 2592×1944, up to 25fps at full resolution.
  • M12 low-distortion lens ensures sharp, accurate, and realistic image capture.
  • Proprietary on-board ISP advances image enhancement.
  • Plug-and-play; USB 2.0 and 3.0 compatible, no drivers needed.
$414.99
This 5mp is a black-and-white global shutter camera from Arducam’s USB 3.0 series, engineered for exceptional imaging performance. Featuring high sensitivity, low noise, and enhanced quantum efficiency (QE) in the near-infrared (NIR) spectrum, this camera excels in low-light conditions.
This camera offers a maximum resolution of 2592×1944 and supports smooth video capture at 25fps in full 5MP resolution. The included M12 low-distortion lens complements the sensor's capabilities, ensuring sharp, accurate, and distortion-free images.
Arducam’s USB 3.0 cameras also incorporate advanced Image Signal Processing (ISP) technology, including de-Bayer, gamma correction, and color correction, to deliver vivid, high-quality images. The plug-and-play ensures compatibility with Windows and Linux systems without the need for additional drivers, while backward compatibility with USB 2.0 ports adds convenience.
  • Mobile Facial Authentication
  • Smart Home Appliances
  • High-Performance Sensor: Black-and-white global shutter camera with high sensitivity, low noise, and enhanced NIR performance.
  • Crisp Imaging: 2592×1944 resolution, 25fps at 5MP, ideal for fast-moving objects with no distortion.
  • Premium Optics: Equipped with an M12 low-distortion lens for sharp, accurate, and realistic image capture.
  • Advanced ISP Features: De-Bayer, gamma, and color correction ensure vivid and detailed image quality.
  • Plug-and-Play Convenience: Compatible with Windows/Linux, no drivers needed, and supports USB 2.0 and 3.0.
Sensor OG05B1B
Still Resolution 5MP
Color Filter Type Mono
Shutter Type Global Shutter
Optical Size 1/2.53"
Pixel Size 2.2 μmx 2.2 μm
Sensor Active Area 2592 (H)×1944 (V)
Frame Rate (USB 3.0) 2592×1944@25fps
Frame Rate (USB 2.0) 2592×1944@5fps
FOV 95°(D)×82°(H)×66°(V)
Lens Mount M12 (S-mount)
E.F.L 3.6mm
Default Focus Range 1m-∞
Power Requirements Max: 1.5W
UVC Controls Brightness, Contrast, Gain, Exposure (Manual/Auto)
  • 1 x Arducam 5MP Mono USB3 Camera with Back Cover and Tripod Adapter
  • 1 x USB A to Type-C Cable (1m)
