This 5mp is a color global shutter camera from Arducam’s USB 3.0 series, engineered for exceptional imaging performance. Featuring high sensitivity, low noise, and enhanced quantum efficiency (QE) in the near-infrared (NIR) spectrum, this camera excels in low-light conditions.
This camera offers a maximum resolution of 2592×1944 and supports smooth video capture at 25fps in full 5MP resolution. The included M12 low-distortion lens complements the sensor's capabilities, ensuring sharp, accurate, and distortion-free images.
Arducam’s USB 3.0 cameras also incorporate advanced Image Signal Processing (ISP) technology, including de-Bayer, gamma correction, and color correction, to deliver vivid, high-quality images. The plug-and-play ensures compatibility with Windows and Linux systems without the need for additional drivers, while backward compatibility with USB 2.0 ports adds convenience.
| Image Sensor | |
| Sensor | OG05B10 |
| Still Resolution | 5MP |
| Color Filter Type | Color |
| Shutter Type | Global Shutter |
| Optical Size | 1/2.53" |
| Output Format | YUY2 |
| Pixel Size | 2.2 μmx 2.2 μm |
| Sensor Active Area | 2592 (H)×1944 (V) |
| Frame Rate (USB 3.0) | 2592×1944@25fps |
| Frame Rate (USB 2.0) | 2592×1944@5fps | Lens |
| Focus Type | Manual Focus |
| FOV | 95°(D)×82°(H)×66°(V) |
| Lens Mount | M12 (S-mount) |
| F.NO | F2.8 |
| E.F.L | 3.6mm |
| Default Focus Range | 1m-∞ |
| USB Interface | |
| Power Requirements | Max: 1.6W |
| UVC Controls | Brightness, Contrast, Saturation, White Balance (Manual/Auto), Gain, Exposure (Manual/Auto) |
