Mega 3MP SPI Camera Module with Camera Case for Any Microcontroller
Mega 5MP SPI Camera Module with Autofocus Lens for Any Microcontroller
B0401
  • Super Easy Using: High-level commands built-in, easy as a DSLR
  • Power Saving: 94ms wake-up and consumption low as under 200mW
  • Sharp Image: 5MP Resolution that can capture clearer and sharper images
  • Wider Compatibility: Compatible with any Microcontroller with a single standard SPI interface
  • Autofocus Lens: Programmable Autofocus function for different distance photography
  • Out of stock, check new version B040101
arducam shipping payment 1
$34.99
Arducam Mega 5MP Rolling Shutter camera is the latest product developed by Arducam Team. The Ultra High Stability and Accuracy and Open Source API of this camera can realize your project more effectively. Arducam team is committed to creating more convenient and more efficient camera solutions. We have expanded the using scope of the image sensor, enabling the camera to realize your various projects. Meanwhile, the camera is featured 5MP Resolution and Super Sharp Images. We equip the camera with Autofocus Stock Lens which will allow you to apply it for your certain projects.
  • Assets Monitoring
  • Space Journey
  • Environmental Observation
  • Dynamics Capture
  • loT Automation
  • Easy Using: Extremely easy to use. High-level commands were built in so you manipulate the camera through API access like using a DSLR camera via button clicks.
  • Programmable Autofocus: Equiped with an Autofocus Lens which can achieve autofocus at different distances. Suitable for the IoT activities.
  • Multiplexing Made Easy: Up to 4 cameras running on a single MCU by using an adapter board. They capture at the same time with sequential readout then.
  • Open Source SDK: The SDK is fully open-source with lean architecture with a hardware abstraction layer, which allows you to add a new MCU without effort.
  • One Fits All: It fits any microcontroller with a single standard SPI interface (either native or mimic). 8-bit, 16-bit or 32-bit, ARM, RISC-V, or others. Arduino, STM8/STM32, ESP8266/ESP32, MSP430, Nordic, Renesas, and countless more.
Item Type Mega
Optical Size 1/4''
Speed 8Mhz
Number of effective pixels 2592x1944
Power Supply 3.3V/5V
Interface SPI(4-wire)
Shutter Type Rolling Shutter
Color Filter Color
Power Consumption(ldle/Working) 182mW-650mW
Field of View 68.75°(D)
F.NO F2.0
Lens Type Stock Lens
Focal Length 3.3mm
Focus Distance 8cm-INF
Electric Current (Idle/Working) 55mA-154mA
Output Format RGB/YUV/JPEG
Overall Size 33x33x17 mm
Connector No. XH2.54-6P
  • 1 x Arducam Mega 5MP SPI Camera
  • 1 x 300mm 6pin cable
  • No MCU board (Arduino, STM8/STM32, ESP8266/ESP32, Rpi Pico, etc) is included in the package
  • Arducam Mega Camera can be used on any Microcontroller board, but note that you will need the corresponding code and software to use it, please refer to the following documentation for details.
