Arducam New 5MP Mega SPI Camera Module with M12 Lens for Any MCU
Arducam New 3MP Mega SPI Camera Module for Any Microcontroller
Arducam New 5MP Mega SPI Autofocus Camera Module for Any MCU
B040101
  • Super Easy Using: High-level commands built-in, easy as a DSLR
  • Quick Response & Power Saving: 94ms wake-up and consumption low as under 100mW
  • Sharp Image: 5MP Resolution with Autofucs Lens which can capture clearer and shaper images
  • Wide Compatibility: Compatible with any Microcontroller with a single standard SPI interface
  • Check Mega SPI 5MP M12 Lens version here: B043601.
$34.99
Arducam New Mega 5MP SPI camera is the latest product developed by Arducam Team. The Ultra High Stability&Accuracy and Open Source API and SDK of this camera module can realize your project more effectively. The camera is featured Low Power Consumption and Super Sharp Image. For this Mega 5MP SPI Camera module, we equip the camera with a 68.75-degree(DFOV) Autofocus Lens for more realistic image output and clarity imaging. What’s more, if off-the-shelf solutions don't meet your needs, Arducam offers end-to-end custom camera design services to help you turn your ideas into real products. From early concept to mass production, we work closely with you to tailor an imaging solution to meet your unique technical requirements and product goals.
  • loT Automation
  • Assets Monitoring
  • Space Journey
  • Environmental Observation
  • Dynamics Capture
  • Easy Using: Extremely easy to use. High-level commands were built in so you manipulate the camera through API access like using a DSLR camera via button clicks.
  • Programmable Autofocus: Equiped with an Autofocus Lens which can achieve autofocus at different distances. Suitable for the IoT activities.
  • Open Source SDK: The SDK is fully open-source with MIT license. A lean architecture with a hardware abstraction layer, enabling you to add a new MCU without effort.
  • One Fits All: It fits any microcontroller with a single standard SPI interface (either native or mimic). 8-bit, 16-bit, or 32-bit, ARM, RISC-V, or others. Arduino, STM8/STM32, ESP8266/ESP32, MSP430, Nordic, Renesas, Raspberry Pi Pico and countless more.
  • Ultra-Low Power Profile: Consumes only 90mW at idle and 550mW under active workload, perfect for power-constrained IoT environments.
Collection Arducam Mega SPI Camera
Resolution 5 Megapixels
Chroma Color
Optical Format 1/4"
Output Format RGB/YUV/JPEG
Pixel Size 1.4µm x 1.4µm
Sensor Active Area 2592(H)×1944(V)
Sensor Image Area 3.65 mm x 2.74 mm (4.567 mm diagonal)
Resolution List (JPEG) 2592x1944, 2048x1536, 1920x1080; 1600x1200, 1280x1024, 1024x768; 800x600, 640x480, 352x288; 320x240, 176x144, 160x120; 128x128, 96x96;
Focus Type Autofocus
FOV(DxHxV) 68.75°(D)x50°(H)x37.5°(V)
Lens Mount Stock Lens Mount
F.NO F2.0
E.F.L 3.3mm
Default Focus Distance 10cm~INF
Interface SPI
Supported Platforms Arduino, ESP32, Raspberry Pi Pico, etc..
SDK Support Support
SPI Speed Max 8MHz
Frame Buffer 8MByte
Camera Controls Saturation, Brightness, Contrast, Ev, White Balance, Special Effects, Exposure Time Adjustment, Gain, Image Quality, Rotation, Framerate Control;
Operating Voltage 3.3V/5V
Electric Current (Idle/Working) 40mA~160mA
Power Consumption (Idle/Working) 90mW~550mW
Camera Board Size 30x30mm
Camera Overall Weight (Net) 17g
Overall Size 33x33x17 mm
Certification RoHS, CE
  • 1 x Arducam New-Gen 5MP Mega SPI Autofocus Camera module for MCU
  • 1 x 300mm 6pin Dupont cable
  • The package contains small contents, please keep it away from children to avoid accidental ingestion.
  • No MCU board (Arduino, STM8/STM32, ESP8266/ESP32, Rpi Pico, etc) is included in the package.
  • When outputting JPEG images, the camera supports a maximum resolution of 2592x1944. In YUV/RAW format, the maximum output resolution is 1920x1080.
  • Arducam Mega Camera can be used on any Microcontroller board, but note that you will need the corresponding code and software to use it, please refer to the following documentation for details.
