[Discontinued] Arducam 1.3MP MT9M001 Color HD CMOS  Camera Module with M12 Mount 6mm Lens
[Discontinued] Arducam 4MP OV4689 1/3
[Discontinued] Arducam 4MP OV4689 1/3" Sensor Standalone Camera Module UC4689-A46
[Discontinued] Arducam 0.3MP MT9V111 1/4'' 640*480 Camera
B0059
0.3MP MT9V111 1/4” 640*480 Camera
$7.35
  • Onboard LDO regulators for 2.8V
  • Single 3.3V power input
  • 2.54mm (0.1 inch) standard pinout
  • SOC Camera Module
  • Active array size: 640 x 480
  • Optical Format 1/4 inch (4:3)
  • Fast Rate: 30fps VGA, 60fps CIF, 90fps QVGA at 27MHz Clock
  • Responsivity: 1.9V/lux-sec (550nm)
  • Dynamic Range: 60dB
  • ITU_R BT.656 (YCbCr), YUV, 565RGB, 555RGB, and 444RGB output data formats
  • External 1/4 inch high quality 6mm/F2.0 M12x0.5 mount
  • MT9V111 640*480 0.3 Mega pixels Camera Module Compatible w/ OV7670
Instruction Manual.pdf
usb_camera_shield_release_blog_thumbnail
ArduCAM USB Camera Shield Released
The ArduCAM USB camera shield is a universal camera control board designed for both PCs and embedded systems like the Raspberry Pi, TI Beaglebone, and similar products. It supports most parallel interface image sensors ranging from 0.3MP to 14MP, including both global and rolling shutter sensors. The camera is packaged with the software you need to put it to […]
You can purchase this item fromArducam distributors
