Arducam 1/2.5
Arducam 1/2.5" M12 Mount 6mm Focal Length Camera Lens M2506ZH04
Arducam 1/2.5
Arducam 1/2.5" M12 Mount 16mm Focal Length Camera Lens M2016ZH01
Arducam 1/2.5" M12 Mount 8mm Focal Length Camera Lens M2508ZH02
LN002
  • What else is needed: It makes a perfect combo with “Arducam B0031 or B0103, a more flexible and slightly larger camera module for Raspberry Pi that uses M12 lenses to frame up the best image. You can’t use this lens directly with the official Raspberry Pi Camera Module V2 because an M12 holder or 18/20mm hole spacing of the camera board is required
$9.99
  • Optical Format: 1/2.5”
  • Effective Focal Length: 8mm
  • 35mm equivalent focal length: 86.5mm
  • FOV on 1/2.5”sensor(D/H/V): 50°/40°/30°
  • FOV on 1/2.7” sensor(D/H/V): 48°/42°/25°
  • FOV on 1/2.8” sensor(D/H/V): 45°/40°/23°
  • FOV on 1/2.9” sensor(D/H/V): 43°/38°/22°
  • FOV on 1/4”RPi Camera(D/H/V): 32.5°/26°/19.5°
  • F/NO: 2.0
  • Mount: M12
  • Length Holder Height: 13mm
  • Size: 14mm x 16.9mm
  • Weight: 7g
Lens Specifications
Mechanical Drawing
  • Arducam 1/2.5" M12 Mount 8mm Focal Length Camera Lens M2508ZH02
Lens holder options
U0756M16 16.5mm 20.0mm Metal
U0756M14 14.5mm 20.0mm Metal
U0756M13 13.0mm 20.0mm Metal
LH003  12.0mm 18.0mm Plastic
M12_Lens_kit_thumbnail
Arducam M12 lens kit
