Arducam 1/2.5
Arducam 1/2.5" M12 Mount Camera Lens M25360H06
Arducam 1/2.5
Arducam 1/2.5" M12 Mount 8mm Focal Length Camera Lens M2508ZH02
Arducam 1/2.5" M12 Mount 6mm Focal Length Camera Lens M2506ZH04
LN003
M12 Mount lens mainly for Arduino and Raspberry Pi cameras, please contact us for other platform.
Why we need it: In case you’re disappointed with the fixed official cameras and want precise control of what gets into the frame of your image – like how wide and how close it is
What else is needed: It makes a perfect combo with “Arducam B0031 or B0103”, a more flexible and slightly larger camera module for Raspberry Pi that uses M12 lenses to frame up the best image. You can’t use this lens directly with the official Raspberry Pi Camera Module V2 because an M12 holder or 18/20mm hole spacing of the camera board is required
How to use it: Get a camera with an M12 lens holder, and screw one lens slowly into the M12 lens holder until you see a clear and sharp image on a video screen. Screw it out a little if you want to shoot objects close to the camera.
$9.99
  • Optical Format: 1/2.5”
  • Effective Focal Length:6mm
  • 35mm equivalent focal length: 64.9mm
  • FOV on 1/2.5” sensor(D/H/V): 67°/53°/41°
  • FOV on 1/2.7” sensor(D/H/V): 64°/57°/34°
  • FOV on 1/2.8” sensor(D/H/V): 62°/55°/33°
  • FOV on 1/2.9” sensor(D/H/V): 60°/53°/32°
  • HFOV on 1/4” RPi Camera: 33°, F/NO: 2.0
  • Mount: M12, Length Holder Height: 13mm
  • Size: 14mm x 17.4mm, Weight: 5g
Lens specifications
Mechanical drawing
  • Arducam 1/2.5" M12 Mount 6mm Focal Length Camera Lens M2506ZH04
Lens holder options
U0756M16 16.5mm 20.0mm Metal
U0756M14 14.5mm 20.0mm Metal
U0756M13 13.0mm 20.0mm Metal
LH003  12.0mm 18.0mm Plastic
M12_Lens_kit_thumbnail
Arducam M12 lens kit
