The Arducam IMX415 MIPI Camera Module is a 8.3MP open-source camera designed for Raspberry Pi and embedded Linux systems, featuring Sony’s STARVIS sensor for excellent low-light performance and crisp 3840 x 2160 resolution. It comes with a pre-tuned M12 wide-angle lens and integrated 650nm IR filter, offering a ready-to-use solution for a wide range of vision applications. This variant is supported by upstreamed libcamera drivers, full hardware schematics, and 3D files for smooth integration and customization.
8.3MP Ultra HD Clarity
Captures high-resolution images at 3840(H) × 2160(V) with a fine 1.45µm pixel size, delivering crisp, detailed visuals ideal for advanced imaging and machine vision tasks.
Excellent Low-Light Performance
Powered by Sony’s high-sensitivity STARVIS IMX415 sensor with back-illuminated pixel technology, the camera performs exceptionally well in dim or low-light environments, ensuring clear imaging even in challenging lighting conditions.
Optimized M12 Lens Selection
Pre-tuned with a wide-angle M12 lens that’s carefully selected to match the sensor's performance. It includes a built-in 650nm IR cut filter for accurate daytime color reproduction.
Open-Source Friendly
Designed for seamless integration with Raspberry Pi and embedded Linux systems, the module supports upstreamed libcamera drivers and provides full schematics, enabling customization and ease of development.
Robust Developer Ecosystem
Backed by community-supported libcamera tuning, developers can fine-tune image quality and parameters to meet the unique requirements of their vision-based projects.
| Image Sensor | |
| Sensor | IMX415 |
| Still Resolution | 4K |
| Color Filter Type | Color |
| Shutter Type | Rolling Shutter |
| Optical Size | 1/2.8'' |
| Output Format | RAW10 |
| Pixel Size | 1.45 µm x 1.45 µm |
| Sensor Active Area | 3840(H)x2160(V) |
| Resolution@Frame Rate | [email protected] |
| Lens | |
| Focus Type | Fixed Focus |
| FOV | 104°(D)×88°(H)×47°(V) |
| Lens Mount | M12 Mount |
| F.NO | F1.0±10% |
| E.F.L | 3.9±5% mm |
| Default Focus Range | 3m-INF |
| IR Sensitivity | Integral 650nm IR Filter |
| Operating Voltage | 3.3V |
| Operating Temp. | 0°C to 70°C |
| Power Consumption | MAX:1W |
| Camera Board Size | 24mm x 25mm |
| Supported OS | Bookworm |
| Supported Platforms* | Raspberry Pi 5/4B/3B+/3/2/CM3/CM4/Zero W/Zero 2 W |
| Exposure Time Range | 3840x2160: 0.113~954421.703 ms |
Supported Platforms*: This camera module supports, including but not limited to, the platforms listed above.
