IMX415 MIPI Camera Module for RPi, Arducam OpenSource Camera
IMX335 MIPI Camera Module for RPi, Arducam OpenSource Camera
B0568
  • [5MP High res.] 2592(H) x 1944(V) active area with 2.0µm pixel size.
  • [Good Low light performance] Sony STARVIS IMX335 sensor with back-illuminated pixel technology used.
  • [Selected M12 Lens] Pre-tuned M12 wide angle lens with integrated 650nm IR filter.
  • [Open-Source Ready] Upstreamed libcamera drivers, full schematics, and 3D files, seamless integration with Raspberry Pi and embedded Linux.
  • [Developer Ecosystem] libcamera community-supported tuning for custom projects.
$37.99
The Arducam IMX335 MIPI Camera Module is a 5MP open-source camera designed for Raspberry Pi and embedded Linux systems, featuring Sony’s STARVIS sensor for excellent low-light performance and crisp 2592×1944 resolution. It comes with a pre-tuned M12 wide-angle lens and integrated 650nm IR filter, offering a ready-to-use solution for a wide range of vision applications. This variant is supported by upstreamed libcamera drivers, full hardware schematics, and 3D files for smooth integration and customization.
  • Industrial Inspection
  • Smart Traffic Systems
  • Surveillance & Security
  • Agricultural Tech
  • Embedded Vision Prototyping
  • 5MP High Resolution Delivers detailed and sharp images with a 2592(H) x 1944(V) active pixel array and a 2.0µm pixel size, offering high clarity for both general imaging and vision-based applications.
  • Good Low-Light Performance Built around Sony’s STARVIS IMX335 sensor with back-illuminated pixel technology, this module performs well in low-light environments, making it suitable for indoor, dusk, or controlled lighting conditions.
  • Optimized M12 Lens Selection Equipped with a carefully selected M12 wide-angle lens that has been pre-tuned for the sensor. It includes a built-in 650nm IR cut filter for accurate color reproduction under normal lighting.
  • Open-Source Friendly Fully compatible with Raspberry Pi and embedded Linux systems, the module comes with upstreamed libcamera drivers, open schematics, and 3D models, ensuring smooth integration and flexibility for developers.
  • Robust Developer Ecosystem Supported by the active libcamera community, this camera module is ideal for custom tuning and prototyping, allowing developers to fine-tune ISP parameters and adapt the module to specific use cases.
Sensor IMX335
Still Resolution 5MP
Optical Size 1/2.8''
Output Format RAW10/RAW12
Pixel Size 2.0 µm x 2.0 µm
Sensor Active Area 2592(H)x1944(V)
Resolution@Frame Rate 2592x1944@30fps
FOV 104.9°(D)×82.4°(H)×53°(V)
F.NO F1.6±10%
E.F.L 4.3±5% mm
Default Focus Range 1.9m-INF
Operating Voltage 3.3V
Operating Temp. -10°C to +60°C
Power Consumption 1W
Camera Board Size 24mm x 25mm
Supported OS Bookworm
Supported Platforms* Raspberry Pi 5/4B/3B+/3/2/CM3/CM4/Zero W/Zero 2 W
  • 1 x 5MP IMX335 Low Light MIPI Camera Module
  • 1 x 15cm 15pin-22pin Ribbon Cable 1 x 15cm 22pin-22pin Ribbon Cable
  • Quick Start Guide
  • 3D Drawing-Compatible Case
  • Schematic
