The store will not work correctly when cookies are disabled.
JavaScript seems to be disabled in your browser.
For the best experience on our site, be sure to turn on Javascript in your browser.
NEW
Arducam IMX900 Series Camera Module —
Stereo · USB · GMSL Multi-Cam ,
built for Robotics , 3D Capture & In-Vehicle Vision .
Shop the Series
Arducam USB2 Camera Shield (Rev.E) - Support MIPI Interface and Parallel Interface Sensors
[Discontinued] Arducam Parallel Camera Adapter Board for USB3 Camera Shield
[Discontinued] Arducam CMOS Camera Adapter Board for Omnivision Image Sensor
This adapter board can Support most OmniVision COMS Camera module.
8bit pin header style camera breakout board support
0.3MP : OV7670, OV7725
1.3MP: OV9650
2MP: OV2640
3MP: OV3640
5MP: OV5642
Single power supply range:2.8V~3.3V
8 bit RGB/YUV/Raw camera data bus
Pin pitch:2.54mm
Can be used in MCUs, ARMs, CPLD, FPGA, DSP paltform
Signal Definition
VCC: Power Supply
GND: Power Ground
SCL: I2C Clock
SDA: I2C Data
VSYNC: Vertical Sync
HREF: Horizon Reference
PCLK: Pixel Clock
XCLK: Master Clock
D0~D7: Data Bus
Y0~Y1: LSB in YUV 10 bit mode
Flash: Optional Flash signal
PWDN: Power down input ard
1 pcs CMOS Camera Adapter Board for Omnivision Image Sensor
