[Discontinued] Arducam IoTai ESP32 CAM WiFi Bluetooth PSRAM Development Board with Camera Module OV2640
[Discontinued] Arducam CMOS Camera Adapter Board for Omnivision Image Sensor
Arducam USB2 Camera Shield (Rev.E) - Support MIPI Interface and Parallel Interface Sensors
B0175
Discontinued, please check the upgraded version: B0419
$69.99
The highlight of the new USB2.0 camera shield Rev.E is that it supports MIPI interface sensors without any MIPI adapter board. It has onboard 16MByte hardware frame buffer, and overcome the bandwidth and dropping frames issue when using the software frame buffer scheme. In addition, with onboard frame buffer it supports synchronized multiple cameras taking images exactly at the same time. Now it well supports both PC and embedded system like Raspberry Pi, and also can provide customized support for Odroid, Beaglebone Black, Nvidia Jetson TK/TX boards.
  • Support MIPI interface sensors
  • Support 8-bit Parallel image sensors by a Parallel Camera Adapter Board
  • Support 12bit Parallel image sensors
  • Build-in IRCUT control (optional)
  • Support x86, ARM 32/64bit hardware platforms
  • Support Windows, Linux OS
  • Bandwidth:480Mbps USB2.
  • I/O Voltage Standard: 3.3V
  • Connector: Micro-USB2.0
  • Onboard Frame Buffer 16MBytes
  • Size: 40 x 40 mm
  • Weight: 20g
  • Power Consumption: 5V/300mA
  • IoT cameras
  • Robot cameras
  • Wildlife cameras
  • Machine vision
  • Scientific cameras
  • 1pcs Arducam USB2 Camera Shield (Rev.E) - Support MIPI Interface and Parallel Interface Sensors
  • 1pcs USB2.0 micro-USB Cable
  • 1pcs 150mm 15pin 1.0mm to 22pin 0.5mm pitch FPC cable
  • 1pcs 80mm 22pin 0.5mm pitch FPC cable
Supported Camera Modules
Please check this page for the featured supported parallel and MIPI cameras of the Arducam USB2.0 camera shield(Rev.E).
NOTE
Camera module/breakout is not included, should order separately.
2_gen_usb2_camera_shield_blog_thumbnail
Second Generation ArduCAM USB2.0 Camera Shield
The second generation of Arducam USB2.0 shield is designed to replace the old one released on March 2017 while keeping the same form of factor and software compatible. The highlight of the new USB2.0 camera shield is that it has onboard 8MByte hardware frame buffer, and overcome the bandwidth and dropping frames issue when using […]
USB2.0 Camera Shield Rev.E
GitHub
ArduCAM/ArduCAM_USB_Camera_Shield
