Arducam 12MP IMX708 102 Degree Wide-Angle Fixed Focus HDR High SNR Camera Module for Raspberry Pi
$ 29.99
  • Complementary to RPI V3: A fixed focus supplement to the Raspberry Pi IMX708 autofocus camera module 3.
  • Superior Sensor: Sony IMX708 with HDR mode for up to 3-megapixel output, MIPI CSI-2 Communication.
  • Wide Angle Fixed Focus: 102°(HFOV) Wide Angle Fixed Focus Lens, integral IR-cut filter. With Fixed Focus Lens, you can get a more stable and quickly generated image.
  • Platform Compatibility: Supports Raspberry Pi 3, 4 A/B, equipped with 15-22pin and 15-15pin FPC flexible cables. Supports application on Raspberry Pi Zero.
  • Cost-effective: second-to-none choice for given image and cost.
  • Check 66 degree standard angle version: B0308, Check 120 degree Ultra Wide-Angle version: B0310
arducam shipping payment 1
Raspberry Pi Camera Module 3 series is the latest camera series released by Raspberry Pi Official in 2023. Arducam has designed a Fixed-Focus camera variant based on the Official Wide-Angle Camera Module 3. The camera adopts Sony 11.9MP IMX708 Image Sensor which can be used to take full HD video as well as still photographs and features an HDR mode of up to 3 megapixels.
It is equipped with a 102 Degree Wide-Angle Fixed Focus Lens and integrated IR-cut filter which is more stable and fast when focusing compared with the Autofocus Lens, especially for the wide range projects. It is fully supported by the libcamera and Picamera2 library.
Arducam is committed to creating diverse and convenient camera solutions. Also, we designed various accessories for the Raspberry Pi Camera Module 3. Among them, include Camera Extension solution, Quad-Vision stereo camera kit, UVC USB camera solution, and upcoming FPD-Link solution, etc. For details, please refer to our official website www.arducam.com
  • Wildlife Photograph
  • Machine Learning
  • High-Quality Monitor
  • AI applications
  • Wide-Range Project
  • Complementary to RPI V3: A fixed focus supplement to the Raspberry Pi IMX708 autofocus camera module 3, catering to lots of use cases where auto-focus lenses are improper or unsafe.
  • Arducam Camera Module 3: Based on back-illuminated stacked CMOS 12-megapixels high resolution Image Sensor (Sony IMX708) with HDR mode for up to the 3-megapixel output. Same basic functions as Raspberry Pi Official Camera Module 3.
  • Wide Range Quality Images: Armed with a 102° Wide Angle Fixed Focus Lens. Wide-Angle Lens allows a wider field of view for landscape photography. The max resolution reaches 4608 × 2592. Along with built-in 2D DPC and QBC Re-mosaic function, offering a high signal-to-noise ratio (SNR). The high resolution and performance of the sensor enable the camera to capture ultra-high-quality images.
  • Native to Raspberry Pi: Natively supported by Raspberry Pi. No additional driver is needed when using the camera on Raspberry Pi. You only need to make some modifications in the config file.
  • Platform Compatibility: Supports Raspberry Pi 3, 4 A/B, equipped with 15-22pin and 15-15pin FPC flexible cable. Supports application on Raspberry Pi Zero.
Image SensorIMX708
Still Resolution11.9 Megapixels
Video Modes2304 × 1296p56, 2304 × 1296p30 HDR, 1536 × 864p120
Sensor Resolution4608 x 2592 pixels
Sensor image area6.45 x 3.63mm (7.4mm diagonal)
Pixel Size1.4μm × 1.4μm
Optical Size1/2.43"
IR SensitivityIntegral IR-cut Filter, visible light only
Supported PlatformRaspberry Pi 5/4B/3B+/3/2/CM3/CM4/CM5/Zero W/Zero 2 W
Focus TypeFixed Focus
Focal Length2.75mm
F.NOF2.2
Field of View(FOV)120°(D)x102°(H)x67°(V)
Lens Mount/
Default Focus Distance1.5m -∞
Camera Board Size25 × 24mm
  • 1 x Arducam 12MP IMX708 Wide-Angle Fixed Focus camera module
  • 1 x 150mm 15pin-22pin FPC Cable
  • 1 x 150mm 15pin-15pin FPC Cable
  • No Raspberry Pi board is included in the package
  • This camera is natively supported by Raspberry Pi, you don’t need an additional driver to run it, but you will need some configuration, please refer to the following doc.
Weight0.05 kg
Native Camera
IMX708
12MP
HDR
Fixed Focus
