Raspberry Pi Official Camera Module V3-12MP IMX708 102° Wide Angle Autofocus Camera with Acrylic Case
$ 59.99
  • Raspberry Pi Camera Module 3: Raspberry Pi official third-generation camera module.
  • High Resolution: Based on 12MP IMX708 Image Sensor, max resolution is 4608×2592. HDR mode for up to 3MP.
  • PDAF&CDAF: Mixture of Phase Detection Autofocus and Contrast Detection Autofocus.
  • Wide Angle: 102°(HFOV) Autofocus Lens, integral IR-cut filter. Check Standrad Angle version: B0306
  • Acrylic Case: Arducam camera enclosure case designed for v1/v2/V3 boards. Click Here for the single case.
arducam shipping payment 1
Raspberry Pi Camera Module 3 is the latest camera model released by Raspberry Pi Official in 2023. The camera adopts Sony 11.9MP IMX708 Image Sensor which can be used to take full HD video as well as stills photographs, and features an HDR mode up to 3 megapixels.
The camera is equipped with a 102° Wide Angle Lens which integrates IR-cut filter and adopts Phase Detection Autofocus technology. It is fully supported by the libcamera and Picamera2 library. Camera Module 3 is compatible with all Raspberry Pi computers.
Arducam is committed to creating diverse and convenient camera solutions. We designed various accessories for the Raspberry Pi Camera Module 3. Among them, the Arducam camera enclosure case is fully compatible with Raspberry Pi V1/V2/V3 and Arducam 16MP/64MP cameras.
  • Large Scenery Project
  • Learning Camera
  • High-Quality Monitor
  • AI applications
  • Wildlife Photograph
  • Raspberry Pi Official Camera Module 3: Raspberry Pi Camera Third Generation: Back-illuminated and stacked CMOS 12MP high resolution Image Sensor (Sony IMX708) with HDR mode for up to 3-megapixel output
  • High-quality Images: Max Resolution: 4608 × 2592. Along with built-in 2D DPC and QBC Re-mosaic function, offering High signal-to-noise ratio (SNR)
  • PDAF&CDAF System: Mixture of Phase Detection Autofocus and Contrast Detection Autofocus . By reserving PDAF and CDAF pixels on the photosensitive element, then the offset value of the focus is calculated from the phase difference and check the highest contrast to achieve accurate focusing
  • Wide Angle Lens: 102°(HFOV) Autofocus Lens. The wide-angle lens has a shorter focal length and a larger viewing angle, allowing you to capture a large area of scenery within a short shooting distance
  • Acrylic Case: Arducam camera enclosure case designed for 25*24mm, v1/v2, and the official camera module V3 boards (Standard, Wide, NoIR and NoIR Wide)
Image SensorIMX708
Still Resolution11.9 Megapixels
Video Modes2304 × 1296p56, 2304 × 1296p30 HDR, 1536 × 864p120
Sensor Resolution4608 x 2592 pixels
Sensor image area6.45 x 3.63mm (7.4mm diagonal)
Pixel Size1.4μm × 1.4μm
Optical Size1/2.43"
IR SensitivityIntegral IR-cut Filter, visible light only
Supported PlatformRaspberry Pi 5/4B/3B+/3/2/CM3/CM4/CM5/Zero W/Zero 2 W
Focus TypeMotorized
Focal Length2.75 mm
F.NOF2.2
Field of View(FOV)120°(D)x102°(H)x67°(V)
Lens Mount/
Camera Board Size25 × 24mm
  • 1 x Raspberry Pi Official camera module v3(Wide Angle) with a 150mm 15pin FFC cable
  • 1 x 150mm 15pin-22pin FPC Cable
  • 1 x ABS Camera Case
  • No Raspberry Pi board is included in the package
Weight0.05 kg
Native Camera
IMX708
12MP
HDR/Wide Angle
Auto Focus
