64MP Autofocus Synchronized Quad-Camera Kit for Raspberry Pi
$ 298.96
  • Multiplexing with ultra high res: 4 x 64mp cameras on 1 Pi.
  • Synchronized: up to 4 cameras capturing at the same time.
  • Autofocus: AF/Manual/Continuous-AF out of the box.
  • Better Control: single/dual/quad channel modes.
  • Highly Compatible: libcamera-ready, works well with most Pi models.
  • Four in One: Combine four cameras into one frame, each camera with a max resolution of 4576(H)x3472(V)
arducam shipping payment 1
A quad-camera kit that allows you to use up to four 64-megapixel autofocus cameras on a standard Raspberry Pi model.
By default, the kit works in a quad-channel mode where all cameras are configured to capture stills/videos at the exact same time.
Supported Modes
Single Channel (no sync):
4 cameras work consecutively where one camera captures after the other. Full res for each.
Dual-Channel (synced):
2 cameras merged into 1 full-res frame, working synchronously. 1/2 res for each.
Quad-Channel (synced):
4 cameras merged into 1 full-res frame, working synchronously. 1/4 res for each.
Demo
Our Camera-Multiplexing Solutions >
Optical Size1/1.7" 9.25mm Diagonal(7.4×5.55mm)
Focus TypeManual/Auto
Sensor Resolution9152×6944
Color FilterQuad Bayer Coding(QBC)
Focus8cm~INF
Focal Length5.1mm
View Angle84 Degrees (Diagonal)
Dimensions25×24 mm
Shutter TypeRolling
Sensor Output FormatsRAW10
Video Modes (Camera Module)*9152×[email protected], 8000×6000@3fps, 4624×3472@10fps, 3840×2160@20fps, 2312×1736@30fps, 1920×1080@60fps, 1280×720@120fps
Platform Output FormatsJPEG/YUV/RGB/RAW10
Video Modes (on Raspberry Pi)1080p30,720p60 and 640×480p60/90
Supported PlatformsRaspberry Pi 5/4B/Pi 2/3/CM3/CM4/CM5/Zero W/Zero 2 W
Raspberry Pi OSbookworm/bullseye(32-bit/64-bit) 01/28/22 or later releases
Documentations
  • The arducam 64MP cameras can only get maximum resolution and video streaming on Pi4 and CM4 platforms. The resolution and video streaming of the camera will be limited on other Raspberry Pi platforms
  • This Kit Combines four cameras into one frame, each camera with a max resolution of 4576(H)x3472(V).
Packing List
  • 4 ×64MP Camera Module
  • 1 ×UC-512 Camarray HAT
  • 5 ×30cm 15-22pin Camera Cable
  • 1 ×30cm 22-22pin Camera Cable
  • 1 ×7cm 15-22pin Camera Cable
  • 1 ×Screw Pack
Note:
*Raspberry Pi and tripod are not included.
*The 64MP cameras in the kit are exclusively made and can only be used with the Camarray HAT. Connecting any of them directly to Raspberry Pi will not work.
FAQs
For dual/quad channel mode, does the kit still use the full sensor as input?
When it’s in sync/4-channel mode, it uses ¼ the pixels of each sensor as input. When you switch to single-channel mode, you can get 4 images at full res!
For single channel mode, what frame rate can I get and how fast can I capture and switch between cameras?
You can get roughly ~8 frames (full res) per second with single-channel mode, and the HAT we designed has the ability to switch to the next camera after each frame, so in theory, you can switch between cameras every ~125 ms (⅛ s), but, and it’s a huge but, it also depends on how fast you can store that full res image, whether you want the HAT to switch to the next camera after a frame’s captured or stored, which Raspberry Pi model you use, etc.
Can this work with your cable extension kit?
Yes.
Weight0.4 kg
Synchronized Multi Camera
64MP
High Resolution, High Speed, Quadrascopic Camera, Synchronized Multi Camera
Auto Focus
