8MP 1080P Wide Angle USB Camera with Mini Metal Case, 1/3.2” CMOS IMX179 UVC USB2.0 Webcam Board with M12 Lens, Microphone, 3.3ft/1m Cable for Windows, Linux, Android, and Mac OS-Arducam
SKU: UB022901 Category:
The UB022901 is a new member of Arducam’s USB camera family. It’s an 8MP, UVC compliant, wide angle, M12 USB 2.0 camera.
No longer be anxious about installing the driver! The native UVC drivers of Windows, Linux and Mac shall be compatible with this camera so that it does not require extra drivers to be installed.
  • More than HD: This camera adopts an 8MP IMX179 sensor for sharp images and accurate color reproduction.
  • Wide Angle: High-quality 105-degree view angle (diagonal) M12 lens with IR filter, which provides a much wider Field of View.
  • Plug&Play: UVC-compliant, just connect the camera to a PC computer, laptop, Android device, or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Capture Video with Audio: High frame rates, MJPG 15fps@3264 x 2448, 30fps@1080P; YUY2 30fps@640x 480; Audio, single microphone (optional dual channels).
  • Applications: Comes with a metal case and rotatable bracket, this tiny camera can be installed in a narrow position, highly recommended for monitoring Octoprint 3D Printer, a home video surveillance system and other vision applications demand high resolution.
– Sensor: 1/3.2” IMX179
– Resolution: 8MP 3264H x 2448V
– Data Format: MJPG/YUY2
– Frame Rate: MJPG 15fps@3264 x 2448, 30fps@1080P; YUY2 30fps@640x 480
– Field of View (FOV):105°(D)
– Lens Mount: M12
– IR Sensitivity: Integral IR filter, visible light only Functionality and Compatibility
– Adjustable parameter: Brightness, Contrast, Saturation, Hue, Sharpness, Gamma, Gain, White balance, Exposure.
– Audio: Single microphone (optional dual channels)
– System Compatibility: Windows, Linux, Mac, and Android with UVC. Power
– Power Supply: USB powered 5V
– Working Current: MAX 350mA Physical
– Operating Temp.: -4°F~158°F (-20°C~+70°C).
– Dimension: 40mmx28mmx45mm
– Cable Length: 3.3ft (1M)
Manual.pdf
Manual.pdf
