Arducam 2MP OV2655 1/5″CMOS sensor Standalone Camera UC2655-A24
SKU: U6033 Category:
Application:
  • Surveillance
  • Cellular and picture phones
  • Toys
  • PC multimedia
  • Digital still cameras
Details
  • Ultra-low power and low cost
  • Automatic image control functions: automatic exposure control (AEC), automatic white balance (AWB), automatic band filter (ABF),
    automatic 50/60Hz luminance detection, and automatic black level calibration (ABLC)
  • Programmable controls for frame rate, AEC/AGC 16-zone size/position/weight control, mirror, and flip, scaling, cropping and windowing
  • Image quality controls: color saturation, hue, gamma, sharpness (edge enhancement), lens correction, defective pixel canceling, and noise-canceling
  • Support for output formats: RAW RGB, RGB565/555, YUV422/420, and YCbCr422
  • Support for images sizes: UXGA, and any arbitrary size scaling down from SXGA
  • Support for video or snapshot operations
  • Support for horizontal and vertical sub-sampling
  • Support for internal and external frame synchronization
  • Support for LED and flash strobe mode
  • Standard serial SCCB interface
  • Digital video port (DVP) parallel output interface
  • MIPI serial output interface
  • Support for second camera sharing ISP and MIPI interface
  • Embedded one-time programmable (OTP) memory
  • On-chip phase lock loop (PLL)
  • Programmable I/O drive capability
  • Support for black sun cancellation
  • Suitable for module size of 6.5mm * 6.5mm
  • High dynamic range (HDR) mode for SVGA (800 * 600) or lower resolutions providing a dynamic range of~85dB
Key Specifications
  • Active array size: 1600 * 1200
  • Power supply:
    core 1.5VDC ± 5%,
    analog 2.6~3.0V,
    I/O 1.7~3.0V
  • Power requirements:
    active 250mW,
    standby 75 uA
  • Temperature range:
    operating -20℃ to 70℃ (see table 8-2),
    stable image 0℃ to 50℃ (see table 8-2)
  • Output formats (8-bit): YUV (422/420)/YCbCr422, RGB565/555, 8-/10-bit raw RGB data
  • Lens size: 1/5″
  • Lens chief ray angle: 25° non-linear (see table 10-1)
  • Input clock frequency: 6~27 and 54 MHz
  • S/NS ratio: 37 dB
  • Dynamic range: 66 dB
  • Maximum image transfer rate:
    UXGA (1600 * 1200) 15 fps for UXGA and any size scaling down from SXGA,
    SVGA (800 * 600) 30 fps for SVGA and size scaling down from SVGA
  • Sensitivity: 1030 mV/(Lux • sec)
  • Shutter: rolling shutter
  • Scan mode: progressive
  • maximum exposure interval: 1235 * tROW
  • Gamma correction: programmable
  • Pixel size: 1.75 um * 1.75 um
  • Well capacity: 7 Ke
  • Dark current: 4 mV/sec @ 60℃
  • Fixed pattern noise (FPN): 1% of VPEAK-TO-PEAK
  • Image area: 2842 um * 2121 um
  • Package dimensions: 4835 um * 4895 um
DVP
2MP
Others
