Arducam M12 Mount Camera Lens M25170H12
  • What else is needed: It makes a perfect combo with “Arducam B0031 or B0103, a more flexible and slightly larger camera module for Raspberry Pi that uses M12 lenses to frame up the best image. You can’t use this lens directly with the official Raspberry Pi Camera Module V2 because an M12 holder or 18/20mm hole spacing of the camera board is required
SKU: LN007 Categories: , ,
  • Optical Format: 1/2.5”, Effective Focal Length:1.7mm
  • 35mm equivalent focal length: 18.4mm
  • FOV on 1/2.5” sensor(D/H/V): 180°/180°/140°
  • FOV on 1/2.7” sensor(D/H/V): 180°/180°/180°
  • FOV on 1/2.8” sensor(D/H/V): 180°/180°/180°
  • FOV on 1/2.9” sensor(D/H/V): 180°/180°/180°
  • HFOV on 1/4” RPi Camera: 118°, F/NO: 2.0
  • Mount:M12, Length Holder Height: 13mm
  • Size: 20mm x 18.7mm, Weight: 8g
Lens specifications
Mechanical drawing
  • 1pcs Arducam M12 Mount Camera Lens M40180H10
Lens holder options:
SKUHeightHole SpaceingMaterial
U0756M1414.5mm 20mmMental
U0756M13 13mm 20mmMetal
LH00312mm 18mmPlastic
U0756M10 10mm 20mmMetal
LH0028.5mm 18mmPlastic
U0756 7.0mm 20mmMetal
LH001 6.0mm 18mmPlastic
M12_Lens_kit_thumbnail
Introduction
Arducam M12 lens kit
3D Drawing.STEP
3D Drawing.STEP
IR sensitivity
Visible Light
