Arducam M12 Mount Camera Lens M27210H08, 1/2.7″ Optical Format, 2.1mm Focal Length
  • What else is needed: It makes a perfect combo with “Arducam B0031 or B0103, a more flexible and slightly larger camera module for Raspberry Pi that uses M12 lenses to frame up the best image. You can’t use this lens directly with the official Raspberry Pi Camera Module V2 because an M12 holder or 18/20mm hole spacing of the camera board is required
SKU: LN005 Categories: , ,
  • Optical Format: 1/2.7”,
  • Effective Focal Length:2.1mm
  • 35mm equivalent focal length: 22.7mm
  • FOV on 1/2.7” sensor(D/H/V): 136°/130°/101°
  • FOV on 1/2.8” sensor(D/H/V): 131°/125°/94°
  • FOV on 1/2.9” sensor(D/H/V): 127°/120°/89°
  • HFOV on 1/4” RPi Camera: 73°, F/NO: 2.0
  • Mount: M12, Length Holder Height: 13mm
  • Size: 14mm x 15.2mm
  • Weight: 5g
Mechanical drawing
  • 1pcs Arducam M12 Mount Camera Lens M27210H08, 1/2.7″ Optical Format, 2.1mm Focal Length
Lens holder options
SKUHeightHole SpacingMaterial
U0756M1616.5mm20.0mmMetal
U0756M1414.5mm20.0mmMetal
U0756M1313.0mm20.0mmMetal
LH003 12.0mm18.0mmPlastic
U0756M1010.0mm20.mmMetal
M12_Lens_kit_thumbnail
Introduction
Arducam M12 lens kit
IR sensitivity
Visible Light
