- Optical Format: 1/2.5”
- Effective Focal Length: 8mm
- 35mm equivalent focal length: 86.5mm
- FOV on 1/2.5”sensor(D/H/V): 50°/40°/30°
- FOV on 1/2.7” sensor(D/H/V): 48°/42°/25°
- FOV on 1/2.8” sensor(D/H/V): 45°/40°/23°
- FOV on 1/2.9” sensor(D/H/V): 43°/38°/22°
- FOV on 1/4”RPi Camera(D/H/V): 32.5°/26°/19.5°
- F/NO: 2.0
- Mount: M12
- Length Holder Height: 13mm
- Size: 14mm x 16.9mm
- Weight: 7g
- IR Sensitivity: sensitive to visible light, with 650nm IR filter
Lens Specifications
Mechanical Drawing
- Arducam 1/2.5″ M12 Mount 8mm Focal Length Camera Lens M2508ZH02
- Lens Holder NOT included, you need to order it seperately.
- Typically lenses with a larger Field of View will require shorter holders, and that means you need to change the lens holder if the lens does not focus at all.
Lens holder options
| SKU | Height | Hole Spacing | Material |
| U0756M16 | 16.5mm | 20.0mm | Metal |
| U0756M14 | 14.5mm | 20.0mm | Metal |
| U0756M13 | 13.0mm | 20.0mm | Metal |
| LH003 | 12.0mm | 18.0mm | Plastic |
Introduction
