- Optical Format: 1/2.5”
- Effective Focal Length:16mm
- 35mm equivalent focal length: 173mm
- FOV on 1/2.5” sensor(D/H/V): 29°/23°/17°
- FOV on 1/2.7” sensor(D/H/V): 25°/22°/12°
- FOV on 1/2.8” sensor(D/H/V): 23°/20°/11°
- FOV on 1/2.9” sensor(D/H/V): 20°/18°/10°
- HFOV on 1/4” RPi Camera: 10°, F/NO: 2.0
- Mount:M12, Length Holder Height: 13mm
- Screws, specifications, and instructions for changing lens provided.
- IR Sensitivity: sensitive to visible light, with 650nm IR filter
Mechanical drawing
- 1pcs Arducam 1/2.5″ M12 Mount 16mm Focal Length Camera Lens M2016ZH01
- Lens Holder NOT included, you need to order it seperately.
- Typically lenses with a larger Field of View will require shorter holders, and that means you need to change the lens holder if the lens does not focus at all.
Lens holder options
| SKU | Height | Hole Spacing | Material |
| U0756M16 | 16.5mm | 20mm | Metal |
| U0756M14 | 14.5mm | 20mm | Metal |
| U0756M13 | 12.0mm | 20mm | Metal |
| LH003 | 12.0mm | 18mm | Plastic |
Introduction
