Arducam IMX219 Low Distortion IR Sensitive (NoIR) Camera Module, drop-in replacement for Raspberry Pi V2 Camera and NVIDIA Jetson Board
[Discontinued] Arducam 8MP 1080P Auto Focus USB Camera Module with Microphone, 1/3.2” CMOS IMX179 Mini UVC USB2.0 Webcam Board with 3.3ft/1m Cable for Windows, Linux, Android and Mac OS…
[Discontinued] Arducam IMX219 Wide Angle NoIR IR sensitive Camera Module, drop-in replacement for Raspberry Pi V2 Camera and Nvidia Jetson Nano
B0194
Discontinued, check alternative B0180
  • Easy installation: Just detach the original stock IMX219 module onboard and re-attach this replacement gently and carefully
  • NoIR lens: The camera is attached with a NoIR M12 Lens which can be used under low light condition
  • Wide Application: Drones, robots, action cameras and 3D scanning applications, so on
  • Camera board is not included in the package, please make sure you have the IMX219 Camera board before purchasing the product
was $29.99 Special Price $12.99
This Arducam IMX219 NoIR IR sensitive fisheye lens camera module is designed mainly for Raspberry Pi V2 camera board and Nvidia Jetson Nano, replacing the default standard IMX219 camera module to get much wide field of view. It can be used for drone, robot, action camera and 3D scanning applications.
★KERNEL CAMERA DRIVER USED
  • Cellular phones, PDAs, Toys
  • Drone, robot
  • Action camera
  • 3D scanning applications
  • All Raspberry Pi platforms
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
IR Sensitivity without IR-cut filter, sensitive to IR light
Focal Length 1.3mm
F.NO F2.0
Field of View(FOV) 155°(H)×115°(V)×175°(D)
Electrical & Mechanical
Peaking Current 300mA
  • 1 x Arducam IMX219 NoIR IR sensitive Wide Angle Camera Module
Raspberry Pi 5 √ √
3D Drawing
Used on Pi
8MP IMX219 Standard Camera Modules
Introduction Arducam team just released an 8MP Raspberry Pi compatible camera based on the same Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports 1080p30, 720p60 and 640x480p90 video. It attaches to Pi by the dedicated standard CSi interface. It is supplementary for Raspberry Pi official camera in […]
Used on Jetson
IMX219 – 8MP Camera
3D drawing_case.step
2 comments
Selection Guide
Edit
