Arducam IMX219 Wide Angle Camera Module, drop in replacement for Raspberry Pi V2 and NVIDIA Jetson Camera
Multi Camera Adapter Module V2.2 for Rasperry Pi Camera Module 3 12MP IMX708 / 5MP OV5647 / 8MP IMX219 / 12MP IMX477 Cameras
Arducam Sensor Extension Cable for Raspberry Pi Camera Module V2, 300MM/1FT Cable to Extend IMX219 Sensor for Smaller Enclosure, Narrow Space and Spy Camera Project, Work with V2 Camera on Jetson Board
B0186
  • This Sensor extension cable is to extend the IMX219 sensor and fit into the space-constrained environment. It can also be used on the Nvidia Jetson Board
  • Fresh Design: A fresh Arducam design to extend your camera vision on the Raspberry Pi Camera Module V2
  • Easy to SetUp: Just need to detach the connectors and re-attach it with the cable
  • Flexible View: You can put the camera in a smaller enclosure and narrow space, like through a small hole or a tube
  • Various Options: Compatible with Arducam IMX219 Sensor drop-in replacement modules
$12.99
This Arducam 300mm extension cable is only designed for the Raspberry Pi V2 camera board in order to extend the small camera module with much longer distance and fit into the space-constrained environment.
It can also be used for the Arducam Nvidia Jetson Board IMX219 camera board as the Jetson Board is compatible with the Raspberry Pi camera module V2.
KERNEL CAMERA DRIVER USED
SUPPORTED PLATFORM DISCLAIMER
Suitable Sensor Sony IMX219
Sensor Optical Format Type 1/4(Diagonal 4.60mm)
Cable Length 300mm
Cable Width 9mm
Cable Thickness 0.1mm
Electromagnetic shielding With Electromagnetic shielding
  • 1 x Arducam 300mm extension cable for IMX219 Camera Module
  • Raspberry Pi V2 camera board or Arducam Nvidia Jetson IMX219 camera board is needed to work with this extension cable.
  • It does NOT support all sensors except IMX219.
  • Please detach and re-attach the connectors gently and carefully, otherwise you might cause damage to the connection.
  • The Raspberry Pi Camera Module V2 is NOT included.
2 comments
