Arducam 100fps Global Shutter Color USB Camera Board, 1MP OV9782 UVC Webcam Module with Low Distortion M12 Lens Without Microphones
Arducam 2MP Global Shutter USB Camera Board, 50fps OV2311 Monochrome UVC Webcam with Low Distortion M12 Lens Without Microphones
Arducam USB Camera Board for Computer, 1MP 720P 1/4” JXH62 Low Distortion UVC Camera Module USB2.0 Webcam Without Microphone, with 3.3ft/1m Cable
UB0235
$22.99
Arducam UB0235 is a 1MP, based on the 1/4" JXH62 image sensor, UVC compliant, low distortion USB 2.0 camera.
  • High Cost Efficient: This camera adopts the 1MP JXH62 Color COMS sensor, which cuts costs and gets decent image quality.
  • Low Distortion: Assembled with a 60°(H) Low-Distortion (<1%) M12 lens, which minimizes the imaging distortion and which minimizes the imaging distortion.
  • Frame Rates: MJPG 30fps@1280 x 720/640 x 480/320 x 240; YUY2 10fps@1280 x 720; 30fps@640 x 480/320 x 240.
  • Plug&Play: UVC-compliant, just connect the camera to PC computer, laptop, Android device or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: Highly recommended for the video surveillance system, videoconference, dashcam, motoring 3D printer and other vision applications.
SPECS
- Sensor: 1/4” JXH62
- Resolution: 1MP 1280H x 720V
- Frame Rate: MJPG 30fps@1280 x 720/640 x 480/320 x 240; YUY2 10fps@1280 x 720; 30fps@640 x 480/320 x 240.
- Field of View (FOV):60 degree (H)
- Lens Mount: M12
- IR Sensitivity: Integral 650nm IR filter, visible light only
- Adjustable parameter: Contrast/ Saturation/ Exposure/ White balance
- System Compatibility: Windows XP (SP2/SP3), Vista 7/8/10, Linux and Mac with UVC
Power
- Working Current: MAX 200mA
Physical
- Dimension: 32mmx32mm
- Hole Pitch: 27x27mm
- Cable Length: 3.3ft (1M)
Datasheet
Manual
