Arducam B0385 is a new member of Arducam's USB camera family. It's a 1MP, based on the 1/4" color global shutter OV9782 image sensor, UVC compliant, low distortion USB 2.0 camera.
The global shutter sensor's excellent low-light sensitivity makes it shoot crisp sharp and accurate complete color images even for high-speed moving objects.
Iris and face recognition
Astrophotography
Gesture and eye tracking
Depth and motion detection
- Sensor: 1/4” OV9782
- Resolution: 1MP 1280 x 800
- Data Format: MJPG/YUY2
- Frame Rate: MJPG 100fps@1280 x 800/720p/800 x 600/640 x 480/320 x 240; YUY2 10fps@1280 x 800/1280 x 720.
- Field of View (FOV): 70 degrees (H)
- Lens Mount: M12
- IR Sensitivity: IR filter, sensitive to Visible Light
- Adjustable parameter: Exposure/ White Balance
- System Compatibility: Windows, Linux, Mac, and OS with UVC driver
Power
- Working Current: MAX 200mA
Physical
- Dimension: 38mmx38mm (Hole pitch compatible with 34mmx34mm, 28x28mm)
- Cable Length: 3.3ft (1M)
NOTE:
This camera module support trigger via an external signal, please refer to the Arducam Doc page to get the instruction.
