The Arducam RoAD.B 1MP Mono Global Shutter Kit is a purpose-built binocular vision system for robotics and machine vision. Featuring a 55mm baseline and perfectly synchronized monochrome sensors, it is designed to provide high-contrast, distortion-free data that enhances the performance of SLAM, obstacle avoidance, and gesture tracking.
The integrated industrial enclosure makes it a "ready-to-deploy" solution for both desktop development and field deployment. As part of the Arducam RoAD family, this kit is engineered for professionals who require consistency.
We offer long-term supply availability and deep technical support, ensuring that your vision hardware remains stable throughout your product's lifecycle. Whether you are building a prototype or scaling a fleet, Arducam provides the reliability and flexibility needed for successful industrial integration.
Visual SLAM: Accurate environment mapping using high-contrast monochrome feature points.
Obstacle Avoidance: Reliable depth perception for small to mid-sized autonomous robots.
Gesture Recognition: High-speed tracking of hand movements for human-machine interfaces.
Volume & Distance Measurement: Precise spatial calculations for logistics and warehouse automation.
Laboratory Automation: Synchronized high-speed monitoring of mechanical processes.
Monochrome Precision for AI: The monochrome sensors in this kit capture more light and provide sharper edges than color sensors. This is critical for stereo matching algorithms (like Block Matching or SGBM) and feature-based tracking, resulting in faster and more accurate depth maps.
Zero-Distortion Global Shutter: Designed for motion, the global shutter captures the entire frame at once. This prevents the "jello effect" or skewed images when the robot is moving quickly, ensuring that the geometric relationship between the two cameras remains perfectly consistent.
Standardized 55mm Baseline: The 55mm baseline provides a balanced depth range, making it ideal for indoor robotics and close-to-medium range spatial awareness. The fixed mechanical alignment within the enclosure saves hours of calibration time.
External Trigger & Synchronization: Beyond USB connectivity, the customizable trigger port allows the camera to be synced with external hardware, such as IR illumination or other sensors. This ensures the vision system is perfectly timed with the rest of your robotic stack.
Industrial-Ready Deployment: The RoAD.B solution is more than a module—it is a complete kit. With its rugged enclosure and USB-C interface, it can be mounted directly onto robotic chassis or laboratory equipment, providing a professional look and durable performance in industrial environments.
Dual 1MP Mono Image Sensor
Optical Size
1/4''
Color Filter Type
Monochrome
Global Shutter
Sensor Active Area
1280(H) x 800(V)
Max Resolution
2560(H) x 800(V) = 2MP
Pixel Size
3 µm x3 µm
Output Format
YUYV/MJPG
Frame Rate(YUYV)
2560x800@10fps, 1280x400@30fps;
640x200@60fps;
Frame Rate(MJPG)
2560x800@30fps, 1280x400@100fps;
640x200@100fps;
Focus Type
Fixed Focus
FOV
82°(D) x 70° (H) x 55°(V)
Lens Mount
M12*P0.5
F.NO
F2.8
E.F.L
2.8mm
Default Focus Range
50cm-INF
Distortion
-1.50%
Weight
4g
IR Sensitivity
NoIR, Sensitive to IR Light
USB 2.0 Device
Connector
B4B-ZR JST
UVC Compliant
No additional drivers required
Supported Cable Length
1m by default, 3m USB Cable Supported
Supported OS
Windows, Linux
Recommend Sample Application
Amcap for Windows, qv4l2 for Linux
UVC Controls
Brightness, Contrast, Gamma, Sharpness, Backlight Compensation, Gain, Exposure(Auto/Manual).
Operating Voltage
5 V +/- 5%
Power Consumption
Max: 1.2W
Overall Weight (Net)
68.7g
Binocular Baseline
55mm
Overall Size
86.5x31.4x20.2mm
Temperature range (Storage)
-4°F-167°F (-20°C to +85°C)
Temperature range (Operating)
32°F-122°F (0°C to +50°C)
Certifications
RoHS
1 x Arducam RoAD.B 1MP Mono 55mm Baseline USB2 Camera Module
1 x 1m USB Type-C to USB-A Cable
This module supports customized resolution, frame rate, external trigger, and ROI, etc..
To ensure stable imaging, please try to avoid using this product in complex lighting environments (such as complex outdoor scenes).
