2MP IMX462 Color Ultra Low Light STARVIS Camera Module with 141°(H) Wide-Angle M12 Lens for Raspberry Pi
Arducam PiVariety Camera, 2.2MP Mira220 MONO Global Shutter Camera Module
B0526
  • Mono Global Shutter: Mira220 sensor captures fast-moving objects without distortion.
  • M12 Lens: Low-distortion lens ensures clear, accurate images.
  • High NIR Sensitivity: Exceptional low-light performance at 940 nm.
  • External Trigger: Support using the external trigger function with this camera
  • Raspberry Pi Compatibility: Works with Pi 5/4B/3B+/Zero/CM3/CM4
$109.99
The Arducam Pivariety Camera, featuring the Mira220 2.2MP NIR global shutter image sensor, is designed for high-performance imaging on the Raspberry Pi. With its 1/2.7-inch sensor and a maximum frame rate of 30fps, this camera excels at capturing fast-paced scenes with exceptional clarity.
The low-distortion M12 lens ensures realistic image reproduction, while its high NIR sensitivity makes it ideal for applications in low-light conditions.
Arducam Pivariety is a Raspberry Pi camera solution that leverages the hardware's ISP functions for enhanced performance and greater versatility in camera and lens options. It overcomes the limitations of the closed-source official camera driver and modules (V1/V2/HQ), allowing users to benefit from well-tuned ISP features such as Auto Exposure, Auto White Balance, Auto Gain Control, and Lens Shading Correction.
  • Mobile Facial Authentication
  • Smart Wearable Devices
  • Mira220 Mono Sensor: Features a global shutter for capturing fast-moving objects without distortion, even in challenging conditions.
  • Low-Distortion M12 Lens: Ensures clear and accurate images, maintaining quality even during high-speed capture.
  • High NIR Sensitivity: Delivers exceptional low-light performance, especially at 940 nm for near-infrared applications.
  • External Trigger: Reserved external trigger ports, support trigger via external signal.
  • Broad Compatibility: Works seamlessly with Raspberry Pi 5, 4B, Zero, CM3, and CM4 models.
Sensor Mira220
Still Resolution 2.2MP
Color Filter Type Mono
Shutter Type Global Shutter
Optical Size 1/2.7"
Output Format RAW12 (Mono)
Pixel Size 2.79μmx 2.79μm
Sensor Active Area 1600(H)×1400(V)
Video Modes 1600x1400@30fps, 640x480@80fps
FOV 80°(D)×68°(H)×53°(V)
E.F.L 3.6mm
Distortion <-0.35%
IR Sensitivity Without IR-cut Filter
Operating Voltage 3.3V
Working Current Max: 300mA
Camera Board Size 38 × 38 mm
Supported Platform Raspberry Pi 5/4B/3B+/3/2/CM3/CM4
/Zero W/Zero 2 W
  • 1 x Arducam Mira220 Camera Module
  • 1 x 15cm 15-15pin Camera Cable
  • 1 x 15cm 15-22pin Camera Cable
  • Raspberry Pi Board Not Included: The Raspberry Pi board is not part of the package and must be purchased separately.
  • Camera Compatibility: The Arducam Pivariety camera is exclusively compatible with libcamera. It does NOT support Raspistill or Raspivid.
  • V4L2 Tools Support: V4L2 tools are supported; however, only RAW format images are available, with no ISP (Image Signal Processing) support.
  • Non-Interchangeable Lens: The camera's lens is fixed and cannot be replaced. If you require a different lens, please contact our sales team before purchase.
