Arducam 12MP IMX708 HDR 120°(H) Wide Angle Camera Module with M12 Lens for Raspberry Pi
16MP IMX519 Camera Module with 122°(D) M12 Lens, Wide Angle Color Rolling shutter for Raspberry Pi and OpenHD
2MP IMX462 Color Ultra Low Light STARVIS Camera Module with 141°(H) Wide-Angle M12 Lens for Raspberry Pi
B0444
  • Ultra Low Light: Ultra low light Sony STARVIS IMX462 image sensor. Supports capturing images in extremely low light conditions(even 0.001 Lux)
  • Manual Focus M12 Lens: Armed with a 141.4°(HFOV) wide-angle M12 Lens. Especially suitable for specific environments like micro, low light, etc.
  • Platform Compatibility: Supports Raspberry Pi 3/4/5/Zero/CM3/CM4. Native to Raspberry Pi.
  • Maximum frame rate in Full HD 1080p mode: 60 fps
  • Flexible Vision: 24mm x 25mm mini-size camera board size. The tiny size camera allows you to put it in narrow positions for your specific projects.
arducam shipping payment 1
$57.99
The ultra low light image sensor can receive more light in extremely low light conditions, making it widely applicable to special lighting projects such as astrophotography. This camera is based on the SONY IMX462 STARVIS ultra low light image sensor. The sensor has very high performance for better image quality in low-light environments.
The camera is equipped with a 141.4°(HFOV) wide-angle M12 Lens. A manual focus camera allows you to use it in situations such as macro photographs, low light conditions, etc. Meanwhile, this camera is fully supported by libcamera and Picamera2 library.
  • Astrophotography
  • Surveillance cameras
  • FA cameras
  • Exceptional Low-Light Performance: Powered by the Sony STAVIS IMX462 ultra-low-light image sensor, this camera captures crystal-clear images with minimal noise, even in challenging low-light conditions.
  • Wide-Angle Lens for Enhanced Coverage: Equipped with an M12 161° diagonal wide-angle lens, enjoy an expansive field of view to capture more details in every frame.
  • Excellent Compatibility: Fully compatible with Raspberry Pi 5, 4B, 3B, and more. Quick and easy driver configuration ensures seamless camera activation for your projects.
  • Quality Images/Videos: Maximum frame rate in Full HD 1080p mode: 60 fps.
  • Arducam Pivariety Solution: Arducam Pivariety Solution is a well-tuned hardware ISP camera solution that brings the official Pi camera experience to more sensors with enhanced performance and works as a standard V4L2 device.
Image Sensor IMX462
Resolution 2MP
Optical Size 1/2.8''(6.46mm sensor diagonal)
Number of effective pixels 1920(H) × 1080(V)
Pixel Size 2.9μm × 2.9μm
Support Platform Raspberry Pi 5/4/3/Zero/CM3/CM4
Shutter Type Rolling Shutter
Color Filter Array Quad-Bayer RGB
Frame Rate RAW10:1920x1080@60fps
Output Format RAW10
F.NO F2.1±10%
Focal Length 2.1±5%mm
Lens Size (2G5P) M12 Lens
Field of View(FOV) 161°(D)x141.4°(H)x81.7°(V)
Camera Board Size 24 x 25mm
  • 1 x Arducam 2MP Ultra Low Light camera module with M12 Lens
  • 1 x 150mm 15pin-22pin FPC Cable
  • 1 x 150mm 22pin-22pin FPC Cable
  • You will need to install the driver for this camera module on Raspberry Pi, please refer to the following doc for quick start.
Raspberry Pi 5 √ √
