[Discontinued] Arducam 5MP 1080p Pan Tilt Zoom PTZ Camera with Base for Raspberry Pi 4/3B+/3
Arducam 5MP OV5647 Miniature Camera with Flex Cable for Raspberry Pi Zero and Compute Module (NoIR)
Arducam 5MP OV5647 Autofocus Camera for Monitoring 3D Printer, 3.28FT/100CM Long Extension Flex Ribbon Cable for Raspberry Pi
B0176R
  • Convenience: Native to Raspberry Pi 5/4/3B+/3 and more
  • Motorized Focus: See closer and easier than the fixed focus lens, which is better to monitor the 3D printer nozzle and make you pay close attention to your creation
  • Long Extension: 100cm/3.28ft extension cable included, especially useful when you don’t want to place the camera near the Raspberry Pi
$19.99
Most 3D models take more than a few hours to print, so you may wish to leave the 3D printer at some point in the printing process. Using an Arducam camera to monitor 3D printing can make you pay close attention to your creation. Since most cameras are not made specifically for the use of 3D printing software, it is impossible to obtain proper support from the manufacturer. Fortunately, Arducam can help you solve all installation and setup problems.
  • IoT cameras
  • Monitoring 3D Printer
  • Robot cameras
  • Wildlife cameras
  • Can be used in MCU, Raspberry Pi, ARM, DSP, FPGA platforms
    Sensor size 1/4” (OV5647)
    Resolution 5MP 2592×1944
    Field of View (FOV) 54°(H), 44°(V)
    Focus Type Motorized Focus
    Focus Distance 2'' to infinity
    Full-frame SLR lens equivalent 35 mm
    Dimension 25mm×24 mm
    Peak Current 300mA
    • 1×5MP OV5647 camera board with motorized lens for Raspberry Pi
    • 1 set acrylic case for the camera module
    • 1×5.9"(15cm) flex ribbon cable for Raspberry Pi Model A&B series
    • 1×5.9"(15cm) flex ribbon cable for Raspberry Pi Zero
    • 1×39.4"(100cm) flex ribbon cable for Raspberry Pi Model A&B series
    • 3×Manuals
    • Raspberry Pi Board is not included in the package
    • The camera's autofocus function needs to be operated by using python scripts, etc. Please see the following documentation for detail
    • Contact [email protected] for customization and [email protected] for support
      Raspberry Pi 5 √ √
    Manual
