Arducam 200MP Motorized Focus USB 3.0 Camera Module
Arducam 20MP AR2020 Monochrome Fixed Focus USB 3.0 Camera
Arducam IMX519 FPD-Link SerDes V3Link USB 3.0 Camera Kit
B0514
  • UVC compatible, up to 10m extension.
  • Include 1×IMX519 CMOS, connect up to 2 cameras.
  • Adaptable channel switching.
  • Plug-and-play, no drivers.
  • Custom camera support available.
$299.99
Arducam unveils its latest breakthrough by integrating FPD V3LINK with USB 3.0 cameras. Harnessing the unique extension capabilities of FPD V3LINK technology, this cutting-edge solution empowers users with unmatched flexibility in extending USB cameras. The kit includes a 1m coaxial cable, offering users the freedom to select the suitable coaxial cable for extending their projects by an impressive 10 meters.
Central to the kit is the formidable IMX519 16MP camera, ensuring superior imaging performance. It seamlessly supports the output of YUY2 uncompressed format, delivering crystal-clear and highly detailed images. Moreover, the kit facilitates the connection of up to two identical IMX519 cameras, catering to versatile applications, particularly in the realm of Automotive ADAS.
Switching between the two camera channels is made effortless—simply click the Backlight Comp button on the UVC Control Panel to swiftly transition between the channels, thereby enhancing adaptability across various scenarios. To guarantee stable operation, the kit comes equipped with a 12V external power supply, furnishing sufficient power for uninterrupted performance. Furthermore, boasting UVC compatibility, the kit ensures seamless connection without necessitating any additional driver support.
How to Switch the Camera Interface:
By default, the camera uses the Cam0 interface.If you need to connect to the Cam1 interface, follow these steps:
1.  Open the camera software, and click"Video Capture Filter/Filter Properties".
2.  Switch to the "Video Proc Amp" tab.
3.  Click "Backlight Comp" to switch the camera to the Cam1 interface.
  • Industrial Systems
  • Security Surveillance
  • 3D Scanning and Metrology
  • Medical Systems
  • Automotive ADAS
  • UVC-compatible FPD V3LINK extension kit allows for flexible setups up to 10m, ensuring seamless integration into various environments.
  • Harness the power of IMX519 CMOS excellence with the included camera, with the option to connect up to 2 cameras simultaneously for enhanced versatility.
  • Adaptable channel management empowers synchronized camera channels, enabling easy switching to capture different perspectives effortlessly.
  • Effortless plug-and-play functionality eliminates the need for drivers, streamlining setup and ensuring quick deployment for immediate use.
  • For additional camera support beyond IMX519, Arducam offers tailored solutions, ensuring compatibility and addressing specific project requirements effectively.
Sensor IMX519
Still Resolution 16 Megapixels
Optical Size 1/2.53"
Pixel Size 1.22 µm x 1.22 µm
Sensor Active Area 4656(H)×3496(V)
Frame Rate (USB 3.0) 1280*720@80fps, 1920*1080@60fps, 2320*1748@25fps, 3840*2160@15fps, 4656*3496@8fps
Frame Rate (USB 2.0) 1280*720@10fps
Focus Type Motorized Focus
FOV 80°(D)×66°(H)×52(V)
Lens Mount Stock Lens
F.NO F1.75
E.F.L 4.28mm
Default Focus Range 10cm-∞
Power Requirements Max: 2.0W , Min: 1.2W
External Power Requirements DC 12V/3A (5.5*2.1mm Barrel Connector)
Camera Board Size 24×25 mm
UVC Controls Brightness, Contrast, Saturation, White Balance(Manual and Auto), Gain, Exposure(Manual and Auto), Focus(Manual), Backlight Comp(switch Cam0/Cam1)
  • 1× Arducam V3Link USB3 Rx board with Metal Case
  • 1× Arducam V3Link Tx board with IMX519 Camera Module
  • 1× 1m Fakra Z Female to Female RF Coaxial Cable
  • 1 x 12V 3A Power Adapter
