Arducam 2.2MP Mira220 MONO Global Shutter USB 3.0 Camera
Arducam IMX519 FPD-Link SerDes V3Link USB 3.0 Camera Kit
Arducam 200MP Motorized Focus USB 3.0 Camera Module
B0527
  • Capture 200MP images for stunning clarity and visual effects.
  • Smooth motion recording at 120fps@720p, 1080p60, 4k@20fps.
  • Superior image quality with de-Bayer, Gamma, BLC, AE, AWB, CCM, and RGB2YUV processing.
  • Motorized focus and 88° FOV for precise, comprehensive surveillance.
  • Plug-and-play compatibility with Windows and Linux, no drivers needed.
$499.99
Arducam's new 200MP USB 3.0 camera features a Sony 1/1.4" sensor with a max resolution of 16320x12288. It delivers clear images and accurate color reproduction, supporting AEB/AEC for optimal exposure.
Equipped with a motorized lens, the camera supports adjusting focus through software, boasting an 88° FOV, and 10cm MOD. The camera now supports YUYV format output for uncompressed, high-quality pictures. Additionally, its ultra-fast 1080P60/4k@20fps capability delivers silky-smooth HD videos.
  • Machine Vision
  • Video Surveillance
  • 3D Scanning and Metrology
  • Live Streaming
  • Video Conferencing
  • 200MP Superior Imaging: Capture breathtaking still images at 200MP ultra-high resolution CMOS sensor, delivering unparalleled clarity and stunning visual effects.
  • Flexible Frame Rate: Program your desired frame rate for smooth motion recording, achieving up to 60fps even at 1080p resolution.
  • Advanced Image Enhancement: Onboard ISP technology ensures superior image quality with features like de-Bayer, Gamma correction, BLC, AE, AWB, CCM, and RGB2YUV processing.
  • Precision Focus: Motorized focus adjustable via software provides precision, while an 88-degree diagonal field of view ensures comprehensive surveillance and optimal clarity.
  • Plug-and-Play: Enjoy seamless compatibility with Windows and Linux systems for true plug-and-play functionality without the need for additional drivers.
Still Resolution 200 Megapixels
Optical Size 1/1.4"
Output Format YUV/RAW
Pixel Size 0.56 μm x 0.56 μm
Sensor Active Area 16320(H) x 12288(V)
Frame Rate (USB 3.0)* YUV: 1280×720@120fps, 1920×1080@60fps, 3840×2160@20fps,
4080×3072@13fps,8160×6144@3fps
RAW: 16320×6144@1fps**
Frame Rate (USB 2.0) 1280x720@10fps
Focus Type Motorized Focus
FOV 88°(D)×75°(H)×60°(V)
Lens Mount Stock Lens
F.NO F1.65±5%
E.F.L 6.14 mm
Default Focus Range 10cm-∞
Power Requirements Max: 2.32W, Min: 1.1W
UVC Controls Brightness, Contrast, Saturation, White Balance (Manual/Auto), Gain, Exposure (Manual/Auto), Focus(Manual)
Frame Rate (USB 3.0)*: Please note that the maximum resolution (16320x12288) requires using specific software, please click the "Quick Start Guide" below for details.
16320×6144@1fps**: The output here is actually 16320x12288 (maximum resolution) RAW format data output. YUV data packets are used internally to transmit RAW data, so the resolution appears to be half the size, but it is actually 200MP.
  • 1 x Arducam 200MP Camera Module
  • 1 x USB Cable (1m)
  • 200MP imaging resolution is currently supported exclusively on Windows 10/11 platforms, with Linux compatibility remaining unimplemented at this stage.
