Arducam. Raspberry Pi. Native AI. Where seamless integration meets unrestricted vision. The Ultimate Drop-In AI Camera Solution
Arducam’s latest innovation brings the full power of Sony’s IMX500 Intelligent Vision Sensor to the Raspberry Pi ecosystem in an ultra-compact, industrial-grade form factor. Engineered as a seamless, high-efficiency alternative to the official Raspberry Pi AI Camera, this module delivers identical, uncompromised AI performance while eliminating mechanical and optical constraints. Native Compatibility, Unlocked Potential
Built to be 100% code-compatible, this module runs all official Raspberry Pi AI demos, examples, and libcamera stacks right out of the box. Developers can now transition effortlessly from proof-of-concept to field deployment without rewriting a single line of code. By combining on-chip AI processing with Arducam’s hardware expertise, we offer a scalable, deployment-ready vision platform for the next generation of edge AI.
These application examples are for reference only. For custom lens matching and specific industrial integration, please contact our engineering team.
Note: Optimized for production-ready edge AI inference where reliability, spatial efficiency, and thermal stability are critical.
Industrial Automation & AGVs
● Precision Robotics & AGVs: Deploy the 50° or 72° Low-Distortion lenses for precise lane tracking, obstacle detection, and warehouse navigation.
● Defect & Anomaly Detection: Utilize the 20° Telephoto lens for high-resolution visual inspection on rapid conveyor belts without moving the camera closer to hazardous zones.
● Safety Perimeter Monitoring: Leverage the 140° or 180° Ultra-Wide/Fisheye lenses to ensure 360-degree blind-spot human presence detection around industrial machinery.
Smart Retail & Space Analytics
● Privacy-First Crowd Analysis: Run on-chip segmentation to track foot traffic, queue lengths, and customer demographics, transmitting only anonymized metadata to comply with strict privacy laws.
● Automated Inventory Auditing: Use long-range optics for ceiling-mounted shelf-scanning and stock-taking robots.
Agricultural IoT & Outdoor Surveillance
● Crop Growth & Disease Tracking: Deploy low-power Raspberry Pi nodes in fields with 88° Wide-Angle optics for periodic leaf segmentation and early pest identification.
● Weather-Hardened Infrastructure: Perfect for remote monitoring stations where extreme temperature fluctuations demand certified component stability.
100% Raspberry Pi Ecosystem Compatible -Zero-Effort Migration: Fully compatible with all official Raspberry Pi AI frameworks, drivers, and pre-trained models. Enjoy identical AI processing speed and intelligence as the official hardware, backed by the familiarity of the Pi ecosystem.
Advanced Thermal Management & Industrial Reliability -High-Temp Performance: At an ambient temperature of ~50°C, the camera maintains a stable 38°C after 5 minutes and remains at 54°C after 1 hour of continuous operation. -Low-Temp Performance: In sub-zero conditions ( -10°C), the camera reaches 31°C within 5 minutes and maintains -2°C after 1 hour of sustained use. -Stability Validation: Passed strict high-and low-temperature testing. Continuous AI demo execution for 24+ hours with zero frame drops, streaming interruptions, or abnormal reboots.
Ultra-Compact, Space-Saving Footprint -24x25mm Form Factor: Stripped of unnecessary bulk, this mini-module fits into the most space-constrained enclosures, handheld devices, and compact drone bays where the official camera cannot go.
Versatile M12 Optics Options Check M12 Lens Bundle Kit here: LK006 -Tailored Field of View (FOV): Break free from fixed lenses. This module supports a versatile range of industrial-grade M12 lenses to perfectly match your target distance and scenery: --20° H Telephoto: For long-distance detail magnification. --50° H Low-Distortion: For precision metrology and scanning. --72° H Standard: Balanced FOV for general machine vision. --88° H Wide-Angle Low-Distortion: Expanded view without geometric warping. --140° H Ultra-Wide & 180° H Fisheye: Maximum situational awareness and panoramic tracking.
1 x Arducam IMX500 AI Camera Module with M12 Lens for Raspberry Pi
1 x 15cm 15-22pin FFC Cable
1 x 15cm 15-15pin FFC Cable
Lens Selection: The camera module can be purchased with a pre-configured lens option or as a bare kit. Check the M12 Lens kit for B0670 Here: LK006. Ensure you select the appropriate FOV according to your application’s working distance.
Thermal Note: While the built-in heatsink and enclosure significantly lower chip operating temperatures by over 10°C compared to alternative designs, ensure adequate passive or active airflow within tightly sealed industrial enclosures during 24/7 heavy AI workloads.
Software Stack: No proprietary drivers are required. Please ensure your Raspberry Pi OS is updated to the latest version to utilize the native libcamera and AI demo libraries.
M12 Lens Bundle kit for Arducam IMX500 M12-mount AI Camera
