Arducam 20MP AR2020 Color USB 3.0 USB UVC Camera
8MP A219 Autofocus USB2 UVC Camera Module with Metal Case, HDR-enabled Module Available
2.8-12mm Varifocal Lens Web Camera with 1/2.8" IMX291 Image Sensor, 1080P@30fps WDR Low Light USB Camera with CCTV Video Lens for Android, Linux, Windows and Mac OS-Arducam
B0362
$59.99
This 2MP Varifocal USB Camera is based on 1/2.8” IMX291 image sensor, optical zoom, UVC compliant USB 2.0 cameras.
No extra drivers needed, the native UVC drivers of Windows, Linux and Mac shall be compatible with this camera.
Auto control the focusing process to capture the moving object, works like the human eye, and shots the imaging you want.
HD resolution meets your request for higher quality video still pictures resolution.
  • HD 1080P USB Camera: Arducam Full HD Webcam is equipped with CMOS IMX291 with high definition 1920 X 1080P resolution. Built-in a single microphone, auto white balance, and auto-exposure control, this USB camera can supply crisp images and crystal video at a fluid 30 frames. Compression format: MJPG / YUY2/H.264, give you more storage for the video uploading.
  • 2.8-12mm Optical Zoom: 2.8-12mm varifocal lens USB camera with IR-cut filter@650nm can get a clear image in different focus distance, and the minimum focusing distance is 10mm, just zoom and manual focus to obtain different angles of view from 70°-35°.
  • WDR and Low Light: Designed for both low light and high dynamic range scene performance. Up to 80dB high dynamic range and 0.001lux illumination can deliver decent and smooth image quality, even in dim or poorly backlit settings.
  • Plug & Play: 2 Megapixel USB camera board is UVC-compliant, just connect the camera to a PC computer, laptop with the USB cable without extra drivers to be installed. Compatible with Windows/Linux /Mac OS/Android, support OTG protocol and Raspberry Pi.
  • Applications: This mini camera is highly recommended for embedded projects, such as the industrial system, security camera system, video surveillance system, live streaming, video conference, dashcam, and other video vision applications that need high frame rates with high resolution.
SPECS
Sensor: 1/2.8” IMX291
Resolution: 2MP 1947(H) x 1109(V)
Data Format: MJPG/YUY2/ H.264
-Field of View (FOV): 70°-35°(H)
Focusing Range: 2.8-12mm
IR Sensitivity: Integral IR filter, visible light only
- Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
- Audio: Single microphone
- System Compatibility: Windows, Linux, Android and Mac with UVC
Power
- Power Supply: DC 5V
- Working Current: MAX 300mA
Physical
- Operating Temp.: -4°F~158°F (-20°C~+70°C)
- Dimension: 38x38x55mm
- Cable Length: 3.3ft (1M)
Video conference
Day&night low light vision security camera system
Dash cam
Monitoring 3D printer
Baby Camera
Robot and machine vision
Manual.pdf
